Mercedes E63 w\ Kleemann Supercharger, Headers, Quaiffe LSD+more from GMP Performance
Old Sep 12, 2013 | 02:05 PM
GMP Performance's Avatar
Former Vendor of MBWorld
W211 E500 Estate
The owner of this 2008 E63 has been preparing for his supercharger kit for a while, having brought it to us for a Quaife limited slip differential to set up the car's handling for the future power upgrade. Getting their upgrades from Kleemann, pros at the mechanics of a Mercedes engine, it's no joke to say this E63 will be one bad Benz by the time we're done with it!
Parts Installed:
Mercedes AMG V8 2002 MY-on Quaife ATB Helical LSD differential
Mercedes 63 AMG (M156) V8 Supercharger kit by Kleemann
Mercedes AMG63 Long Tube Kleemann Headers
KLEEMANN Electronic Body Lowering module (EBL)
Mercedes AMG63 M156 Billet Idler Pulleys
The Build
Quaife Limited Slip Differential
First, getting it out!
Quaife versus OEM
Kleeman's lowering module
Before the module
After the module
Kleemann long tube headers
OEM Exhaust
Cats and Resonators removed
Manifolds removed
OEM Exhaust Removed
OEM versus the new Kleemann
Time to start getting it all in
O2 Sensor Installed
All Installed
Old Sep 12, 2013 | 02:06 PM
W211 E500 Estate
Supercharger!
Engine bay before supercharger install
Engine covers and radiator support removed
Intake removed
Power steering tank and lines removed
Removing OEM crank pulley
Kleemann crank pulley installed
Idler pulleys removed
Supercharger tensioner bracket installed
Power steering tank bracket installed
Fuel pressure sensor harness relocated to rear of engine bay
Air intake temp sensor removed
MAP Sensor removed
Intake plenum opened up to expose throttle bodies
Throttle bodies removed
Right throttle body after hand cleaning compared to before
Throttle body wiring harness removed
All parts removed from intake cleaned, inspected and ready to be reused
Fuel injectors installed
Air intake sensor installed
Hole enlarged for installation on supercharger
OEM Bleed port cut down and taped for plug
Air bleed hole plugged
Throttle bodies installed on charger unit
Intake ports getting a good cleaning
Charger is mounted in
Supercharger radiator water pump and the custom bracket we made
Low profile supercharger radiator
Fuel lines connected to fuel block
Radiator and water pump installed
Old Sep 12, 2013 | 02:07 PM
W211 E500 Estate
Horn removed and radiator tank installed
Coolant hoses routed and connected
Air filter housing modified to fit over charger
Wiring the water pump fuse and relay
Radiator coolant lines installed
Horn relocated
Bolt for new pulleys
Bolt sized to fit in hole
Not enough threads on new bolt so we went ahead and machined some more!
Charger pulleys and belts test fitted
Pulling the ECU for programming
Changing spark plugs
This is where we found out that the front bumper cover would need more clearance for all the hoses.
Nothing to worry about! With some careful trimming, we cut away enough space to allow that room.
All foam inserts back into the bumper cover
Bumper, ECU and engine covers all get placed back in
And just like that, this 2008 E63 has morphed into something new, something incredible. Anything rocking that AMG badge is already a stout, powerhouse of a vehicle but when you add the expertise of Kleemann to the mix, you know you're talking something special. Our client is ecstatic and in the end, that's what matters most. We still can't wait to get this bad boy back to do some dyno numbers with though!
To see more on this build, click here!
Old Sep 12, 2013 | 02:11 PM
AMG E Power's Avatar
E55 amg
nice job
Old Sep 12, 2013 | 02:58 PM
GunMoto's Avatar
EG8 | E46 | W211
WOw! Game over! Very nice!!
Old Sep 12, 2013 | 03:04 PM
E55AMGGG04's Avatar
04 w211 E55
Sweet
Old Sep 12, 2013 | 03:15 PM
W211 E500 Estate
Thanks guys, We strive to pay attention to the details
Old Sep 12, 2013 | 03:46 PM
TheOtherDodge's Avatar
2005 E55 AMG
Thanks for all the pics!
Old Sep 12, 2013 | 03:50 PM
viren.89's Avatar
2004 E55 AMG
DAMNNN!!! With pics and all, I felt like I went through a life of a teenage who was skinny and then put on serious mass by working out lol
TBH I was kinda bummed for not being able to see before and after dyno numbers.
Good work though
Old Sep 12, 2013 | 03:51 PM
vioilio's Avatar
2003 E55 AMG
A-W-E-S-O-M-N-E-S-S
This build is truly amazing! Nice and clean. Love the attention to details!
Great Job!!!!
Old Sep 12, 2013 | 04:03 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Mmmmm.....Quaife
Old Sep 12, 2013 | 04:25 PM
baldmike73's Avatar
what are the new numbers - looks awesome
Old Sep 12, 2013 | 04:40 PM
SilverStrk's Avatar
05 E55, 07 ML500
Originally Posted by HeissRod
Mmmmm.....Quaife
Do it... You won't regret it... Changes everything Makes the car WAY more fun to drive.....
Old Sep 12, 2013 | 07:11 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Very nice. How much total for the entire job? Please do post HP numbers when you guys get a chance.
Old Sep 12, 2013 | 07:49 PM
berti_00's Avatar
2016 Cls63s AMG
beautiful clean work, thats how it should be done
Old Sep 13, 2013 | 02:03 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Impressive let us know the dyno number !
Old Sep 13, 2013 | 06:50 AM
slownrusty's Avatar
'06 E55 K2
Great attention to detail, especially all the cleaning, bracketry and fasteners..when you get to that level it is indicative of a trustworthy shop.
Old Sep 13, 2013 | 08:57 AM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Crazy that Kleemann built real headers for the 63 and not those 1 5/8 shorties like they did for the 55.
An E55 build by GMP:
http://www.6speedonline.com/forums/m...take-more.html
Old Sep 13, 2013 | 10:10 AM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
Was anything done to the OEM headbolts? Any concerns there?
Old Sep 13, 2013 | 10:49 AM
FromM3toE55's Avatar
2003 E55 AMG
damn!
Old Sep 13, 2013 | 11:10 AM
aeroman's Avatar
1992 911 C4, 2008 P2 E63 AMG (gone but not forgotten), 2007 SL65 Renntech
What does something like this run for cost?
Old Sep 13, 2013 | 12:20 PM
Lawrence1's Avatar
2011 G55 + others
this is a very nice build.
can anyone tell me what those wheels are on the e55 in the link above? They look like HRE's but i would like to know what sizes, etc. GMP - can you help?
thanks.
Old Sep 13, 2013 | 12:57 PM
MAN55LE's Avatar
04 E55 AMG
WOW thanks for posting all the pics, can't wait for the dyno number, thats awesome
Old Sep 13, 2013 | 01:34 PM
HeissRod's Avatar
thanks.
Looks like HRE 597Rs
Old Sep 13, 2013 | 05:17 PM
W211 E500 Estate
Good work though
Thanks for the compliments. We would love to have the before and after dyno information also. It's definitely a good selling tool but overall the client is very impressed as he drives it daily he definitely has a good gauge of how it felt before and now after of course.
