CL/S- 55 Power
c230 Coupe
CL/S- 55 Power
can the 209 e-55 be tuned to have the same power output as the cl-55? isnt it the same engine? sorry if this has been discussed before-
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Are you referring to the E55 with the supercharger?
Don't let the paperwork fool you. MBZ rates the 2003 W211 E55 at 469HP and the 2003 SL55, 2003 S55 & 2003 CL55 at 493HP. Speculation says the E55 is actually 493hp just like the rest because all the cars make the same torgue - 516 ft-lb. E55 probably loses HP on paper due to some crazy Marketing scheme. The E55 is already the fastest of all 4 due to lighter weight.
For $2995 you can bump that HP to 494HP and torgue to 546 at Renntech.
Super Moderator
Re: Are you referring to the E55 with the supercharger?
Buy one and get it Dyno'd!
Originally posted by BenzoBoi
...can anyone verify that it is really the same hp as the sl/ cl/ s55's? thanks in advance
Re: Re: Are you referring to the E55 with the supercharger?
I have been on the boards not too long and I have been reading bout this for quite some time. Can anyone verify this? I knoe that renntech can get some amazing numbers out of this machine but can anyone verify that it is really the same hp as the sl/ cl/ s55's? thanks in advance
Notice that all the models listed (S55, CL55, SL55, E55) have the same power curves and numbers/ratings.
That photo is straight from the source, and says it all!
Super Moderator
Re: Buy one and get it Dyno'd!
Why be concerned with it? So what if the brochure says 469HP and the car may actually have 493HP. It is still the Fastest Mercedes car to date, with a 0-60 time of 4.5 seconds. At least until the SLR Mclaren hits the US.
Mercedes did the similar "cover-up" with previous E55. The W210 E55 has always been published as 349HP while the 2001-2002 S55 and CL55 were listed as 354 and 355. Look at what my owners manual stated - 355HP SAE:
![](http://www.e55amg.com/files/ECLASSdata.jpg)
ML 320 CDI
Haven't you seen the Brabus CLK K8 at the Frankfut show? They manage to put the SL 55 AMG engine in a CLK. With big modification in the engine bay and on the front of the car, you can put everything.
