Eurocharged - Building a monster E55 (800+ hp content)
Old Sep 30, 2013 | 03:57 PM
blackbenzz's Avatar
haters crazy
Originally Posted by ArmoE55
Jerry tuned Ahmad's car and as far as I know, the cooling wasn't an issue (maybe Ahmad will chime in here). Car put down over 600rwhp on a stock block. That car has a lot more potential.
Cooling is still an issue. If someone plans on just bolting the kit on and going I wish you luck. Hopefully there will be modifications made to remedy the issues. Car could make alot more power
Old Sep 30, 2013 | 04:22 PM
Benz-O-Rama's Avatar
Where you gonna install the VTEC, bro?
Old Sep 30, 2013 | 08:14 PM
Blk04e55's Avatar
2004 E55 AMG
and the blow off valve dawg
Old Oct 29, 2013 | 09:41 PM
dsc's Avatar
dsc
2004 E55
Update?
Old Oct 29, 2013 | 10:41 PM
CLS_724's Avatar
MERC
don't forget about the boost gauge homie
looking forward to seeing this when its finished. Def going to be a beast
Old Oct 30, 2013 | 02:46 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Originally Posted by dsc
Update?
Block being properly machined. Then assembly will begin !
Parts are all ordered and ready to be assembled (-:
Old Oct 31, 2013 | 04:50 PM
  #32
Max.H's Avatar
E55
700+WHP E55 has a nice ring to it... Cant wait to see this monster perform!
Old Oct 31, 2013 | 05:57 PM
  #33
C3Duece's Avatar
2002 C32AMG
Just wondering what the bottle neck is for this 55 series motors to hit 600whp? is it the heads or the blower? The 5.4L fords hit those numbers easily on a pulley/tune and do 700/800whp with the big KB/Whipple blowers.
Old Nov 23, 2013 | 02:33 PM
  #34
MAN55LE's Avatar
04 E55 AMG
Update?
Old Nov 23, 2013 | 05:47 PM
  #35
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
COOLING!!! With bolt-ons I hit 576 on a dyno dynamics machine over 3 years ago. I check in two weeks ago for the first time in a couple of years and sadly it still hasn't been properly addressed.
Old Nov 23, 2013 | 07:47 PM
  #36
blackbenzz's Avatar
haters crazy
E85
Old Nov 23, 2013 | 08:19 PM
  #37
chiromikey's Avatar
Originally Posted by blackbenzz
E85
I see advancements in making power but still nothing with regards to proper cooling...and not much in regards to tuning either. It seems people are still dealing with the same hiccups we were 4 years ago.
Old Nov 23, 2013 | 08:24 PM
  #38
blackbenzz's Avatar
haters crazy
E85 is not just for power, it runs alot cooler too
Old Nov 23, 2013 | 08:35 PM
  #39
MAN55LE's Avatar
04 E55 AMG
Meth and or killer chiller...?
Old Nov 23, 2013 | 10:02 PM
  #40
BenzoBoi's Avatar
Super Moderator
W221
Best of luck with the build. I'm excited to see how it runs!
Old Nov 23, 2013 | 10:21 PM
  #41
e55amgrocket's Avatar
Dirt Scooters
Some of us have figured out the cooling on the stock blowers...
Old Nov 24, 2013 | 02:45 AM
  #42
chiromikey's Avatar
I understand and agree but after this amount of time a descent i/c should be available...especially with the design already in plain sight (SLR).
Bandaids not solutions imho...
Old Nov 24, 2013 | 02:47 AM
  #43
chiromikey's Avatar
What's up brotha!
Please share
Old Nov 24, 2013 | 06:07 AM
  #44
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
I fully agree to this post. A much better intercooler could potentially completely solve the heat issues
Old Nov 24, 2013 | 08:10 AM
  #45
GregMB's Avatar
EvoSport spent about 18 months on MBWorld hyping a solution.... Then they released the final product with an ugly cobbled-together intake and slapped an $8000 price tag on it.
Sold like hotcakes!
I think Speeddriven might have been working on something too but I don't recall seeing a final product.
-G
Old Nov 24, 2013 | 09:21 AM
  #46
Dirt Scooters
What's up brotha!
Please share
You can make the stock core function way better with some work but you need a rear tank to make the most of it
Old Nov 24, 2013 | 12:28 PM
  #47
chiromikey's Avatar
Let me know what to do with the i/c. I was the first to use a trunk tank back in the day so you know that's a given in my set-up. Some may remember that I even mounted a second heat exchanger under the rear bumper only to confirm that the i/c is what was truly holding us back.
Old Nov 24, 2013 | 01:02 PM
  #48
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Cut the side/end tanks off the intercooler and remove the little chamber walls in there and weld the sides back to the core. I assume this is what amgrocket is referring to.
Some people in the past may have figured this out and tried to keep it a secret selfishly instead of helping the community out. I cut a spare intercooler apart when I was going to make a top mount setup and found these chambers that made the intercooler a "triple pass" setup. The coolant flows in and then goes back and forth 3 times before it exits the intercooler. Water/coolant that is getting hotter and hotter and hotter is not doing any good to cool the charge compared to if it passed through once.
If you were to make it a single pass through design by removing those little chamber walls integrated in those side tanks you should have an improvement.
The other side
Old Nov 24, 2013 | 01:55 PM
  #49
chawkins2001's Avatar
2006 E55 AMG
What's up Mikey, good to see you are still in the game. To answer your question, the intercooler mod I have, the e85 fueling I have, and it by no means comes close to controling the heat issues. Only with meth and a trunk tank filled with ice will that prevent my car from pulling timing.
A small nitrous shot used for cooling is even more effective in controling iats then meth/trunk tan in my case.
Old Nov 24, 2013 | 02:29 PM
  #50
Max.H's Avatar
E55
Exactly
