Pulley 180
as I read it and look back, can say only one thing: deja vu!!!
ps.
I had sent my pulley back, too
No more of the pulley from the EC. Belts destroyed huge amounts.
The pulley must be perfectly balanced.
Do not use without the crankshaft pulley kit extension. (never)
if there's any problems with them, it will appears immed. after installation...!!
ZAYED,,
prefer if you can at least change your injectors temporary, to confirm what's behind the sense....
ZAYED,,
Did you test ev14 in m113k with afr rate, if yes please write yours experiences.
One of very good tuner wrote:
"Ok those are Bosch EV14 which I cannot stand I have had more issues with those then I hate to admit and will not use them any more"
Here we go
unfortunate, i didn't measure an AFR rate, but since that day till now, no any kind of hiccup,,
many friends here using those Bosch EV14, with tuning, if anyone got problem with them pls. chime here...
ZAYED,,
ZAYED,,
I have the Eurocharged 550cc injectors. I have not had any issues with them. I did though have an issue with one of the adaptors that go between the injector and the cars wiring and this has been fixed.
Regards,
OZZYAMG
No one has seemed to provide a clear black and white answer. If they did correct the problem what was done.
Impossible is nothing
