M113k head gasket/long block rebuild
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 9, 2013 | 04:14 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
So I haven't been in the Mercedes game for very long, picked up my E55 in March of this year... but with all other platforms I've had, I'm never afraid to get dirty. I bought the car with around 95k on it and since day one I have experienced the slightest coolant consumption issue so I suspected the engine wasn't 100%. Recently, I had an intercooler hose failure (may have been my own doing) and had the engine get a bit hot (251°F). About a week later, I was doing a nice 150mph pull and I lifted the heads, pressurizing the coolant system and blowing the end tank on the radiator. Time for head gaskets.
Similar to a woman excusing the clutter when a visitor walks in the house, I'll say I don't own a 'shop' and my hands are always covered in dirt and oil so my pictures are messy and not meant to represent the level of care taken in my repairs, lol.
Tearing the car down, I was concerned that the excessive heat possibly warped the heads. The cams looked blued but Craig told me not to be worried.
I sent the heads out for a check and a clean up. I got the heads back, less one valve...
M113k head gasket/long block rebuild-img_20130912_134646_802_zps605f265d.jpg
I'm not entirely sure when it happened, but I bent an intake valve. This could have happened due to valve float on a high speed run, during disassembly, or the machine shop could have mishandled it. Since the rest of the valvetrain looked fine, I put it back together stock. If something happens later, I'll go the modular 4V route and replace with beehive springs lightweight retainers.
Heads looked good, small valve job and a redeck of .007 (well within sealing tolerance so the heads were thankfully not warped at 251°F).
M113k head gasket/long block rebuild-img_20130912_125036_032_zpsec70448c.jpg
M113k head gasket/long block rebuild-img_20130912_190641_374_zps9a8a52c8.jpg
Reassembled
This time around I decided to run ARP studs. This was a mock up picture, the driver side studs actually have to be installed after the heads since the timing cover prevents the head from dropping straight onto the block.
M113k head gasket/long block rebuild-img_20131002_204616_892_zpsa1c88f50.jpg
Timing cover back on (REPLACE the two seals on the back of the timing cover! They're only $6!)
M113k head gasket/long block rebuild-img_20131002_224554_911_zpsf77f30fd.jpg
Heads back on, crank pulley about to go on to begin timing. Quick tip for the crank pulley (and any tight tolerance metal part for that matter), if you heat it to 250 in the oven the pulley will slip right on to the crank and slide all the way into position. This is due to material expansion. If you need a bearing inside a pocket, do the opposite and stick it in a freezer for a few hours.
M113k head gasket/long block rebuild-img_20131003_245756_611_zpsf12e85e2.jpg
While everything was apart, I sent a few parts to my buddy for powder. The considered the timing cover but I ended up just cleaning it really well prior to reassembly.
M113k head gasket/long block rebuild-img_20130913_110436_822_zps53876f8e.jpg
M113k head gasket/long block rebuild-img_20131003_041238_012_zps7efe7e74.jpg
So this is where I'm at now. I still need to reinstall the heads, blower, coolant system, etc. but the hard part is done. I'd really like to bring it up to MIR in November but I have a lot going on right now so we'll have to keep it a tentative. Not like I can get it out of the hole for a proper time with the damn Ventus RS3s.
The next time anything breaks, I'm building the short with high compression CPs and Carillos. Questions/concerns, let me know. I'm here to help, this forum has already helped me out quite a bit this year.
Old Oct 9, 2013 | 05:16 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Would it have been easier to just drop the entire engine if you had the tools or is there enough room in the bay to do this?
Old Oct 9, 2013 | 05:18 PM
berti_00's Avatar
2016 Cls63s AMG
beautiful work man, that blue looks sick
Old Oct 9, 2013 | 10:28 PM
MAN55LE's Avatar
04 E55 AMG
Looks greatkeep up the good work, and good luck
Old Oct 10, 2013 | 10:41 AM
I have the tools If you plan on taking the oil pan off (the lower or both), then I definitely suggest pulling the motor. The lower has to come off to remove the front timing cover but you can do head gaskets without removing the timing cover so if that's you're only aim then it won't be a big deal. I wanted to replace timing guides and chain since the motor has 107k but after looking at it all, I should have just replaced the tensioner, which will already be removed if you're doing head gaskets. The pans are a PAIN if the engine is still in and requires either the engine to be lifted about 10in or the front suspension to drop down.
Thanks! I was iffy but I think it's coming together. I plan on doing away with the stock air intakes so the valves covers should be a little more prominent later.
I got the blower, fuel rail, TB, water injection, surge tanks, misc. brackets, vac routing, upper pan, windage tray, and lower pan in place last night. Excuse the grainy pic, I don't take my good phone out to the garage, lol.
M113k head gasket/long block rebuild-img_20131009_212149_564-1_zps613810f5.jpg
If I don't go out tonight, it'll be headers and FINALLY getting split cooling done. I just did NOT want to do the job with everything so confined at the front of the engine... now I have all the room in the world to do it correctly.
Old Oct 10, 2013 | 11:26 AM
Joncl's Avatar
E55
Good work bud!
I see that you have the aeromotive 340s as your fuel pumps, maybe a tutorial on that
Old Oct 10, 2013 | 12:27 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Very nice ... respect for those that are willing to get their hands this dirty. I would have been too tempted to build the motor if the motor was apart this far .
Old Oct 10, 2013 | 01:17 PM
chawkins2001's Avatar
2006 E55 AMG
Looks awesome Eric.
Old Oct 10, 2013 | 02:25 PM
Originally Posted by Joncl
Good work bud!
I've got a few pictures, I might be able to rustle something up. It requires breaking stuff though (at least the way I did it) so it's an 'all or nothing' kind of thing.
That's actually WHY I didn't pull the motor in the first place, haha. I said if the motor goes on a stand, it's getting new parts and I'm springing for a converter, lol. Maybe this winter on another block.
Originally Posted by chawkins2001
Looks awesome Eric.
Thanks Craig! Trying to chase you down
Old Oct 10, 2013 | 03:03 PM
Joncl's Avatar
E55
Ya bro show us the breakdown step by step with pics
If using the baskets then yes we have to break done plastic
Much better than that horrible design
Old Oct 10, 2013 | 03:34 PM
e55amgrocket's Avatar
Dirt Scooters
Should of done some head work while you had them off
Old Oct 10, 2013 | 03:42 PM
I said I had a few pics... certainly not a step by step. I'll find them and post here.
Don't you start! I considered it but I'll leave it to another longer build, lol.
Old Oct 10, 2013 | 03:55 PM
Joncl's Avatar
E55
Anything is appreciated
Old Oct 10, 2013 | 04:27 PM
Pjnash's Avatar
2005 E55
nice way to go! glad you didnt have any warp at those temps, a little ease to my mind.
Old Oct 11, 2013 | 12:03 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I don't think you did anything to that valve, they're just fugged up from the factory sometimes but still seal after a valve job.
Old Oct 11, 2013 | 10:02 AM
Denroll's Avatar
'06 E55
I love threads like this. The surge tanks and covers came out awesome.
Old Oct 11, 2013 | 03:42 PM
Alright Joncl, here you go.
The Aeromotives are not drop in, like I said... actually nothing installed into the stock baskets will be drop in. There are plastic retainers in the buckets that are sonic welded in and in order for the old pumps to come out and the new pumps to go in with an attached suction filter, these retainers have to be cut out and reinstalled. The old pumps can come out without cutting them out but there are tabs on the top that need to be broken in order for that to happen and there's no room in the bottom for a different suction filter without disassembly and modding of the base. I didn't drill holes in the bottom of the basket because there's a venturi effect being used to transfer fluid from one end of the tank to the other and I didn't want that the effect transfer (which is quite possible).
Recently, I got the heads up that these 340s have been failing. The returnless Cobras on E85 are dropping pumps but my buddies with return style DSMs and Supras so there's one of a few issues... There is a bad batch of 340s out there, the pumps are not actually E85 compatible, or the returnless (voltage variable) fuel system style is prematurely killing them. Walbros are meant to run at 13.5V continuous, which is why they need to be replaced often in a returnless system. I know Aeromotive states these are fine but I have my doubts now. I'll be running them until one drops and researching a better pumps that still fits in our packaging in the interim.
Old Oct 11, 2013 | 03:50 PM
I was a little worried. If the heads were that far out, I would've had the block checked... which would have been a big tear up.
I put it in a lathe to spin it and the head it pretty far out. I'd hate to throw something like that back in when a new one was $25
Thank you sir! I'm considering the 90mm too, but with a bit of a curve ball. We'll see what happens this winter.
Old Oct 23, 2013 | 12:17 PM
Alright, so update. The motor/car went back together last week and upon firing it up it had a NASTY idle (surging between 1000 and 1400rpm) and was popping/backfiring back through the blower. I was stumped. At first I thought it could be bad injectors, old E85, or low pressure. I datalogged and my throttle showed 100% all the time, I was seeing boost at idle (WTF), and I was getting a code for "Throttle/Pedal Position Sensor/Circuit Low Input". At key on, I noticed my throttle body instantly went to full open and stayed there so I thought it was the throttle body... maybe it got knocked around too much while the motor was apart. The boost at idle was really getting to me. Then I realized the bypass valve should be 100% open and if it was boosting then the bypass was closed. I MIXED UP THE CONNECTORS. Five minutes last night to swap the bypass and throttle body connectors and she purrs like a kitten. The connectors are identical (even down to wire colors) so please pay attention when you're putting yours back together.
I'll put it through a few heat cycles at idle and then I'll take it out for a spin probably this weekend to see how she feels. Probably do a compression and leak down this time around... I should have done it when I bought the car.
Old Oct 23, 2013 | 12:29 PM
Pjnash's Avatar
2005 E55
Congrats! nice build. Glad you figured that out.
Old Oct 23, 2013 | 12:45 PM
Max.H's Avatar
E55
Good job!
Old Oct 23, 2013 | 02:36 PM
Joncl's Avatar
E55
Thanks man!
Old Oct 23, 2013 | 02:56 PM
For sure man, I would have junked it too. I was just saying you didn't necessarily damage it yourself. Spun using the stem as an axis , if the head only had radial runout it probably came that way. If there was and vertical runout on the head causing a poor seal, you might have floated it and kissed the piston.
Originally Posted by rockthemullet
I put it in a lathe to spin it and the head it pretty far out. I'd hate to throw something like that back in when a new one was $25.
Old Oct 23, 2013 | 05:05 PM
2006 E55 AMG
Hey brotha, you running the e85 compliant fuel filters from lethal performance? Watch those 340lphs in there, went through 4 in a thousand miles. I just switched to aem 320lphs specifically for e85. Got them off lethals website for $135 shipped each.
Looking good brutha
Old Oct 23, 2013 | 07:37 PM
I gotcha man. I inspected all of the pistons and couldn't find a thing so it's possible it sat that way the whole time.
Looking good brutha
Yea, after our convo about the 340s I'm getting pretty nervous. I'll probably grab a couple to keep on deck and monitor this car and the Cobra to see if they run into any issues
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
