Sh*t happens?
Old 10-12-2013, 01:57 AM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
Sh*t happens?
With $9K+ invested in engine performance mods and weeks of man hours spent, I crack #8 piston on a test run with @56,000 miles on the clock? Really? Having all intentions on taking the 55K mile speed record, I trash the engine 2 weeks before the race. At least I didn't pay for everything in advance and promised my kids the race. Oh, wait.........
Old 10-12-2013, 01:59 AM
berti_00's Avatar
2016 Cls63s AMG
dammmm that sucks :/
Old 10-12-2013, 02:05 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Sorry to hear that! The mileage is irrelevant though. A lean condition will crack a 1500 mile piston in the same exact fashion as a 150,000 mile one. Hopefully you get back rolling soon man.
Old 10-12-2013, 02:11 AM
EREBUS's Avatar
agreed
Old 10-12-2013, 02:16 AM
Jonota's Avatar
2005 E55
Murphy. Sorry man!
Old 10-12-2013, 02:23 AM
EREBUS's Avatar
It wasn't lean? The piston rings cracked and there was a hair line crack on the side of the piston. I have seen lean conditions damage before, this is not the reason.....multiple techs at Grapevine Mercedes said no signs of detenation/lean mixture present. (Cylinder wall has very little to no damage) Loss of power on high boost mixed with oil blow by was the symptoms I experienced. No knocking, no CEL with smooth acceleration and plenty of power at low and mid range.
Old 10-12-2013, 06:06 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
so what's the plan now
Old 10-12-2013, 09:00 AM
Joncl's Avatar
E55
Were you logging? Would be a learning experience to see what happened and what the ecu did
Old 10-12-2013, 09:19 AM
E55Dimon's Avatar
E63S
That's terrible, sorry man. The frustration must be unbearable. New car?
Old 10-12-2013, 09:32 AM
EREBUS's Avatar
I will have a dual wide band and two aeroforce gauges this time around. lol
Old 10-12-2013, 09:36 AM
EREBUS's Avatar
Unless there is a engine angel that could deliver a miracle, I don't know. I might try to fix the piston with JB Weld.
Old 10-12-2013, 09:41 AM
EREBUS's Avatar
Pretty bad when my 13 and 8 year olds tell me it's going to be okay as I'm sucking my thumb in a rocking fetal position. lol. Nah, I've had the bat mobile for @ 3 yrs now.
Old 10-12-2013, 10:48 AM
Joncl's Avatar
E55
May I suggest the dashdaq with the zeitronix for logging
IMO the best to log and you can set up alarms as well
Old 10-12-2013, 02:19 PM
Manuyc's Avatar
06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
dang man sorry to hear that
Old 10-12-2013, 09:53 PM
The actual ring cracked without taking out the upper ringland of the piston? It either got way too hot or it was lean at one point , one of those two. THat condition can cause the ring to expand too much, butting the ends together and causing the rest of the ring to bind in its groove which will then drop out the compression out of that hole until it cools off.
I'm interested to see what your techs find/think.
Also, sent you a Pm let me know if I can help.
Old 10-14-2013, 10:04 PM
Max.H's Avatar
E55
Terrible terrible news... Sorry to hear that.
Sounds like detonation... If it wasn't heat related. Hard detonation can be like a striking the top of the piston with a hammer.
Old 10-15-2013, 11:19 AM
e55amgrocket's Avatar
Dirt Scooters
Sorry to hear about this. Time to go bigger and better right
Old 10-15-2013, 11:41 AM
C_DirtyTwo's Avatar
a land yacht.
haha in for the DIY.
good luck, I'm sure itll all work out
Old 10-15-2013, 01:03 PM
Extreme Dimensions's Avatar
Too Many To List
Lucky man, could have been a lot worse. (ask me how i know).
Sorry to hear about the mishap though.
Old 10-15-2013, 02:32 PM
EREBUS's Avatar
Rings did not break? Top of piston looks great?
Old 10-15-2013, 03:01 PM
E55Greasemonkey's Avatar
Received 1,490 Likes on 986 Posts
This place is a joke.
What am I seeing near the wrist pin hole?
Old 10-15-2013, 03:46 PM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Damn, worse timing bro! At least you have minimum engine damage.
I suggest you install these forged stock replacements..
Old 10-15-2013, 04:20 PM
chawkins2001's Avatar
2006 E55 AMG
Whose tune was on the car?
Old 10-15-2013, 04:57 PM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
Bad injector on that hole? May be worth checking.
Old 10-15-2013, 05:09 PM
marcmaddox's Avatar
The reason i ask is because i had an eerily similar experience with a boosted SBF. Ended up being a bad injector that only malfunctioned when at full pulse width with boosted fuel pressure. It caused that hole to detonate. It too had no real signs of a lean condition, it just cracked the piston between the top and second ring land.
Sorry for the bad luck. It sucks to have so much time and money invested only to have a mystery problem bring it to an abrupt hault.
Quick Reply: Sh*t happens?
