Questions on using OEM Spare Wheels as front drag wheels?
Old Oct 20, 2013 | 11:22 PM
bstudey01's Avatar
2003 E55 AMG
I have considered doing this but have a few questions for those that have.
1) How much do they weigh compared to the stock 18" AMG wheels
2) What size tires are you guys running on them?
3) What's the width of them?
4) Can/Should I use a drag skinny?
Old Oct 20, 2013 | 11:54 PM
E55Greasemonkey's Avatar
This place is a joke.
I wouldn't want to be doing 120mph on a spare rim. FWIW the spare rims are made to be collapsed...meaning, on a rear impact of the vehicle the spare tire in the trunk does not become a projectile, it's "soft" for that purpose.
Old Oct 21, 2013 | 07:40 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
+1 they are not "real" rims.
Old Oct 21, 2013 | 08:33 AM
chawkins2001's Avatar
2006 E55 AMG
I use them brotha and run 215-45-18 radial tires if I am on 255-50-16 drags outback. If you run slicks outback, go with the real bias ply front runners. Gone 150mph with them upfront and drags outback, was silky smooth. Rbj, hammer down both use them too. They weighed in at 31lbs for me with tire and rim.
Old Oct 21, 2013 | 11:17 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you can use then for the 1/4 mile
Old Oct 21, 2013 | 12:04 PM
schino's Avatar
2005 E55, 11 second truck, ducati streetfighter 1098
Technically the track shouldn't let you pass tech but the don't ask don't tell rule should work
Old Oct 21, 2013 | 12:06 PM
bstudey01's Avatar
2003 E55 AMG
I see m&H makes a 185/50R18 drag radial, 26" diameter. Should be perfect on the spare wheels right? Gotta be a much lighter setup than my stock rims and tires, plus less rolling resistance.
http://www.summitracing.com/parts/mnh-rod12r/overview/
Old Oct 22, 2013 | 05:58 PM
bstudey01's Avatar
2003 E55 AMG
Just got SERIOUS!! Ordered the M&H 185/50R18's and two spare wheels off ebay!! That was costly!! Hopefully worth it!! Gonna get one more run in November sometime hopefully real cold and negative DA's too. Likely gonna drop exhaust and pull seats too!!
Old Oct 22, 2013 | 06:29 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
That's a ton of work, drop the exhaust, pull the seats.. Just throw on the front spares and nail that 60' and you'll see 10's
Old Oct 22, 2013 | 06:32 PM
bstudey01's Avatar
2003 E55 AMG
hmmm, that would be much easier. -1500 DA's would help too considering my last run was at +55. We'll see how motivated I am the day before.
Old Oct 22, 2013 | 06:48 PM
Maybe I missed it but which tire are you running out back? MT or Hoosiers?
Old Oct 22, 2013 | 07:05 PM
bstudey01's Avatar
2003 E55 AMG
255/50R16 Hoosier with clk wheels
Old Oct 22, 2013 | 08:23 PM
on the Hoosiers, i ran MT's but if I ever go out again I want to run Hoosiers, the AMG spare wheels up front (if I can ever find I second wheel) and a Braille battery. Lightweight rotors would also be nice oh and a lightweight driver
Old Oct 22, 2013 | 10:44 PM
bstudey01's Avatar
2003 E55 AMG
Braille is much lighter!! I got one used from Shardul works great, but wouldn't daily drive with it doesn't seem to have enough juice to run my 1000 watt JL amp!! My 03 didn't even come with one spare, so I had to buy two off ebay
Old Oct 23, 2013 | 12:55 PM
Max.H's Avatar
E55
+1
These cars sound awful with no exhaust. Like gatling gun going off.
Old Oct 23, 2013 | 12:59 PM
Max.H's Avatar
E55
Just got SERIOUS!! Ordered the M&H 185/50R18's and two spare wheels off ebay!! That was costly!!!
Awesome! Are the M&H's front runners or drag radials?
Old Oct 23, 2013 | 01:47 PM
bstudey01's Avatar
2003 E55 AMG
Drag radials, as, I believe, you cannot mix bias ply, with the radials on the rear. Also it's about the only 18" skinny tire on the market that is 26" tall as well.
Old Oct 23, 2013 | 05:29 PM
RedBullJnky's Avatar
you to Hate
Never had any problems running the spares up front. You made a good choice. good luck on your next track night!
That was the only thing missing for me last year. I was 237lbs then. Now I'm 191 right now.
Old Oct 23, 2013 | 06:14 PM
bstudey01's Avatar
2003 E55 AMG
Thanks, hope to be a member of the 10 sec club shortly!! That's a whole bunch o weight to lose, gotta be worth a tenth,
Old Oct 30, 2013 | 05:17 PM
I don't know if I can call you Big E anymore I should dust the car off and have you come drive it. Between you driving my car, add AMG spare wheels up front and a Braille battery I can knock off 150+ lbs off of my last run and there a few extra rotational mass pounds if I switch to Hoosiers. All you have to do is nail one of your famous 1.49 60' which is .14 better than my 60' and you could be knocking on the door of high 10.4's so when are you coming out to Cali?
