Its been 3 months and I still haven't figured it out. Advanced help wanted! *SOLVED*
NGK 6619 LFR6AIX-11 Single Iridium Spark Plug
SKU: #LFR6AIX-11
ITEM: #NGK6619
Sparkplug.com
Double check, did this look up quick.
$8.48
When you get it running do not beat on it with the crazy fuel mix, but personally would fill it right away with fresh fuel. Purging of the fuel rail taking out about a quart would also be warranted as per 55greasemonkey.
I personally have never seen it before, but anything is possible. That looked very odd to me too, thats why I suggested to check to make sure the supercharger would spinn freely (locked up supercharger causing extreme load on engine). But that is not the case and his supercharger spins freely. The gears should be checkable by simply moving the butterfly valve by hand. you should be able to hear the mechanism moving inside of the throttle valve and it should move smoothly and have a slight amount of restriction on it due to the gearing and motor. I would assume, if the gears are stripped, the butterfly valve will move freely or flop around with zero restriction on it. Wont hurt to check it.
Also, with the fuel pressure tester, I got a sample into a mason jar, and my money says this gas is very well past its due date. Out of curiosity, I tried lighting the mix on fire. Compared to fresh gasoline I had for the lawn care tools (not premium), the fuel from the rail was very very poor in quality. The fresh gas lit easily from the fumes about 2 inches away from the puddle (size of a quarter), and burned for a decent amount of time. The fuel from the car would only light with direct contact to a flame, and made a decent amount of soot from burning it. My photobucket doesn't want to work, so I'll just attach the pictures here.
EDIT: I also wanted to add, the fuel did not at all, smell normal. It almost didn't smell like gas, it had a stale kind of chemically smell to it (Maybe a little bit comparable to turpentine). Hard to describe, but did not smell like fresh gas.
And would it be possible just to turn the fuel pump on through STAR to bleed it from the rail? That would be much easier than turning on the key, bleeding residual pressure, and repeating 1000 times. I could imagine it would take a lot of juice too, so I would keep a charger on it during bleeding.
Also did you get new plugs?
On a side note, what am I going to do with almost 8 or 9 gallons of bad fuel??
After the fresh gas just bleed about a pint then you will be assured that there is fresh gas at the injectors.
Fresh plugs on the way?
