Speakers don't work
Old Oct 31, 2013 | 08:25 PM
Brabus K8's Avatar
05 E55 Brabus
Thumbs up Speakers don't work
So the speakers on the drivers side went out. The right side is fine. Do you think it's the amp or a fuse and where should I look. Thanks in advance for any help.
Old Nov 1, 2013 | 03:06 AM
AMG55TECH's Avatar
2004 E55, 2003 IS300
Driver's side front and rear?? Most likely an amp... No real fuses to check (either it works or it doesn't kinda thing). Have you used the fader/ balance to move the audio around to check the speakers? Has any work been done to the car where a connector could have only been partially plugged in? What audio source are you using? (Cd, radio, cdc, aux)? My audio was action grunt at one point, but I quickly realized that my aux cable was the problem.
Old Nov 1, 2013 | 05:54 PM
Brabus K8's Avatar
05 E55 Brabus
Yes I tried the fader but nothing coming out of left side. I guess I will have to replace the amp. Thanks
Old Nov 4, 2013 | 11:42 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
id say the amp, it might be repairable by a hifi shop
Old Nov 4, 2013 | 11:45 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Audio Gateway is going bad.
Old Nov 4, 2013 | 05:30 PM
Brabus K8's Avatar
05 E55 Brabus
Thanks Guys I think I will get a new amp. Wish I knew more about electronics.
Old Nov 6, 2013 | 09:59 PM
jayjmuir's Avatar
2007 E63 AMG (Dubai), 2009 BMW X5 4.8i Sport (PA)
I still have all the audio components from when I removed the entire stock setup and replaced it with an aftermarket system. When you get sticker shock from the price of new stock audio components, PM me and we can figure out if the part numbers match up. If so, I'll give you a good deal on whatever you need. There is no sense in that stuff collecting dust in my closet.
Old Apr 2, 2025 | 08:31 AM
Darthpulpetx's Avatar
2004 E320 CDI
Thumbs up Worked
thank you I didn’t think of that, haven’t touched an aux in years all good now though
