Please help...Will these wheels fit my e63
e63 amg x 2
Hello everyone, i recently purchased a 07 e63 and now im looking for some new wheels, i came across some wheels i like but im not sure if they will fit as they were on a cls550.
The wheels don't say the offsets but the seller was kind enough to measure the wheels mounting surfaces to the lip and i did some calculations.
The wheels are the following specs:
Front: 20x9 offset 41 Tire size: 255/30/20
Rear: 20x10.5 offset 51 Tire size: 295/25/20
Please help me out, im not sure if the wheels will stick out or will they even clear my calipers.
Thank you,
Glen
Thank you,
Glen
e63 amg x 2
The cls can a be different bolt pattern then the e class? I didn't even know that, can anyone confirm regarding the rear fitment? I really dont want it poking out..
e63 amg x 2
2007 SL55 AMG
around 32 front and 42 rear. So in your case 10mm spacers all around will make them fit perfectly with those tire sizes.
You mentioned they came off of a CLS. If it came off a 219 CLS, I'm pretty sure those the offsets the seller measured were wrong.
e63 amg x 2
Yea i see what your saying as the cls usually has a more aggressive offsets from the factory, these are the measurements of the wheels maybe someone else can double check them:
rear wheels-
>> from the hub mounting surface to inner(towards car) edge of wheel is 7 1/4"
>> from the hub mounting surface to outer(towards curb) edge of wheel is 5"
>> front wheels-
>> from the hub mounting surface to inner(towards car) edge of wheel is 6 1/8"
>> from the hub mounting surface to outer(towards curb) edge of wheel is 4"
I took those numbers and did some calculations i found on Google and that's what i came up with.
Thanks alot
rear wheels-
>> front wheels-
Thanks alot
e63 amg x 2
After doing some more calculations we came up with these numbers:
Rear offset: 28.6
Front offset: 27
Looks like these are the correct offsets, are these still going to fit or will it rub?
Rear offset: 28.6
Front offset: 27
