PLEASE HELP! Car starts then idles low and shuts off!!
Old Nov 28, 2013 | 06:19 PM
m.robel20's Avatar
2007 E63 AMG
I am having issues with my car and I don't know what could be causing this. Hoping someone could help. I filled up last night. This morning I get in my car and start it. It started just fine without a hitch. I sat in my car for an hour talking on the phone and there were no issues. I shut it off. Half an hour later I turned the car back on and it barely wanted to start. It started but was idling around 300-400 RPM. It was fluttering between 0 and 400 once in a while then automatically shut off in about a minute. When I try to give it gas while idling low the car shuts off. I checked the gas cap and is on tight. I do have a check engine light that illuminated along with the slow start low idle. If anyone can give me an idea of what it could be I would really appreciate it!
Old Nov 28, 2013 | 06:51 PM
berti_00's Avatar
2016 Cls63s AMG
Check your coils
Old Nov 28, 2013 | 06:56 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Crank position sensor or fuel pump
Old Nov 28, 2013 | 07:03 PM
m.robel20's Avatar
2007 E63 AMG
berti do you have any links for a DIY? Thank you.
Old Nov 28, 2013 | 07:04 PM
m.robel20's Avatar
2007 E63 AMG
shardul if you have any diy links that would be helpful as well. New to Mercedes and I"m not familiar with the car.
Old Nov 28, 2013 | 07:18 PM
shardul's Avatar
Let me ask you does the car start up fine after it has been sitting for a couple of hours?
Old Nov 28, 2013 | 07:25 PM
m.robel20's Avatar
2007 E63 AMG
shadul, The car was on for an hour on idle with no problems. I shut it off went up to my apartment, about half an hour later went back to my car, tried starting it and thats when the problem started happening. I can hear the engine cranking but I dont get that complete crank. Almost as if its not getting a complete full start. And it will stay on idle around 300-400 rpm for about 30 seconds then stall. I do have a check engine light accompanying the issue but I do not have a code reader.
Old Nov 28, 2013 | 07:41 PM
m.robel20's Avatar
2007 E63 AMG
Here is an update. I let the car sit for about an hour. Went ahead and tried starting the car. It started up just fine. No check engine light. So i put it in reverse and thought about driving around the block. About 100 feet into the road my check engine light came on but the car was driving fine. I felt a slight shake from the car. But that was momentarily. Then I kept driving and the check engine light went out. The car drove smooth. No shakes. no rattles. No noises of any sort. I drove around the block a couple of times and didnt feel anything out of place. No lights came on. Anyone have any idea what could have caused it?
I'm thinking it may have been because I let the car sit at idle for an hour which may have drained something?? and after I drove it around it may have recharged the system?? I have no idea. Id like to know in case of future issues so I know what to do.
Old Nov 28, 2013 | 08:50 PM
shardul's Avatar
Seems like a cps issue if it starts up fine when the engine is cold
Old Nov 28, 2013 | 10:55 PM
AMG55TECH's Avatar
2004 E55, 2003 IS300
+1 on the possability of crank position sensor. Start by seeing what code is in there that caused the check engine light.
