What size Drag Radials ???
Old Dec 1, 2013 | 11:58 AM
xsboost's Avatar
2009 G8 GT 2004 E55 AMG
According to my calculations the stock rear tire height is 25 in
the front tire height is 26in
if I run a 255/60/16 they will be 26in tall
or a 275/40/17 is also 26in tall, just 0.8 in wider
will the taller rear tire set off any trouble codes ABS? or change shift pattern?
due to the increase tire height?
Old Dec 1, 2013 | 02:01 PM
Max.H's Avatar
E55
Looks like the Hoosiers and the Nitto.
Try to keep the diameter the same as stock. You don't want to lengthen the gear ratio on our cars if you don't have to.
Ideally you want to run the smallest tire width / diameter and still get traction.
Old Dec 1, 2013 | 02:44 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
You'd want to run a 255/50/16 not a 255/60/16. More sidewall usually means more traction, so I'd go with the 16s over the 17s. I run the 255/50/16 mickey thompsons and dont have any abs or traction control issues.
Old Dec 1, 2013 | 08:36 PM
xsboost's Avatar
your right 255/50/16 are 26in tall My mistake
255/60/16 are 28in tall
Aknight55 what kind of 60ft you running? with the mickeys
I have only ran it on street tires on two different days
1st one was 12.23@118.83 got rained out, very humid
2nd was 23deg cold day 12.27@121.96
3rd pass same cold day 12.56@121.47
Old Dec 2, 2013 | 03:04 PM
RedBullJnky's Avatar
you to Hate
I've run both MTs and Hoosiers 255/50/16. Never had any problems.
Old Dec 2, 2013 | 06:39 PM
AKnight55's Avatar
Only ran once on the MTs. I think my 60ft was a 1.8x.. I realized after the fact I was around high 20 psi's. I think they do better around 20 psi ..
Ive heard the hoosiers are actually better than the MTs, but they are both good tires.
Old Dec 2, 2013 | 09:42 PM
xsboost's Avatar
I have always used MT's on my turbo buicks and hooked up real good
with the E55 I am running 2.11 2.16 60fts even spinning after the 60ft mark
I will be looking to get a set of the MT's 255/50/16 on the most popular clk wheels
for spring time.
Thank you guys for all the help
Old Dec 2, 2013 | 10:50 PM
you to Hate
for spring time.
Hoosiers @22psi got me a 1.49 60ft.
Old Dec 3, 2013 | 05:22 AM
99lightning's Avatar
99 ford lightning
how many times have you cut a 1.49?
Old Dec 3, 2013 | 12:59 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Not sure where you're getting this info... with the hefty low end torque, the lower final gear certainly wouldn't hurt. Regarding the smallest width with traction, that's really for the guys trying to squeeze the last 0.5mph. I do a lot of racin and my rule has always been go with big, learn the car, kill a couple sets of tires, THEN consider coming down a size for that trap speed. You never know how good of a 60 you can get without eliminating slip entirely.
I run 285/35/18s (25.9in) on the stockers and I plan to run 275/45/16s (25.7in) next season.
Old Dec 3, 2013 | 04:30 PM
1BAMFR's Avatar
SRT8 Jeep
I run Mickey Thompsons at 25# of pressure....tire size is 265 40- 18
Work awesome!
Old Dec 3, 2013 | 04:54 PM
Joncl's Avatar
E55
I think 1 time from looking at sig but maybe he did more
Old Dec 3, 2013 | 09:36 PM
you to Hate
Just once otherwise it's low 1.5s all day
