2 Door Handles later.. still no go
Old Dec 4, 2013 | 02:06 PM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
Thought maybe the Ebay handle I bought wasn't good, so I ordered another brand new one from Mercedes. Well, I still can't open the door with the key in my pocket. If I unlock the rear door, then the front one is unlocked. At this point, I assume it's something inside the door? Can anyone tell me what module or connector may cause this?
Front Right Door is the affected one.
Thanks. 300 dollars later and still no working unlock.
Old Dec 4, 2013 | 02:31 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Door lock actuator? I have a few in stock but I am fairly sure keyless go is a different lock actuator.
Old Dec 4, 2013 | 03:01 PM
typhoon43's Avatar
If I use the remote it unlocks fine. Or if I open any other door from the outside, it then unlocks. It's literally just when it's locked and I try to walk up and open it like I can with the other 3 doors.
Old Dec 4, 2013 | 08:57 PM
shawnoc2003's Avatar
E55, Audi S4
Can you lock it with the door handle?
Old Dec 4, 2013 | 09:29 PM
typhoon43's Avatar
No, I can not. Only the remote.
Old Dec 4, 2013 | 11:42 PM
speedyc43's Avatar
1999 MB C43 2004 E55 AMG, 2004 Suzuki GSXR, gl63
I have the exact same issue. Subscribed
Old Dec 5, 2013 | 09:38 AM
kompressede's Avatar
Sold - 05' E55
I had the same problem about two years ago, only suggestion I have is to make sure the little plug end from the new button is plugged in all the way?
It was the same thing for me, it effected only the drivers door?
Old Dec 5, 2013 | 09:50 AM
mb techman's Avatar
CLA45
Old Dec 5, 2013 | 01:08 PM
typhoon43's Avatar
Originally Posted by mb techman
make sure there is no corrosion in the harness inside the door that plugs in to the keyless go door handle.
That's what I'm thinking at this point. Looks like I'll be pulling the door panel.
