E55 steering noise
Old Dec 4, 2013 | 02:30 PM
viz4575's Avatar
2005 Mercedes E55 AMG
E55 steering noise
Hi i don't want to start a new thread but I can't find anything with the symptoms that I have... My front end is making weird grinding noises, it seems like is coming from the tires... Standing still if I turn the steering wheel left and right it's squeaking like crazy....I appreciate the help on advance
Old Dec 4, 2013 | 04:00 PM
Shadow5501's Avatar
Car free at the moment
Does it make funny (well, un-funny) noises while driving it, particularly while pulling into or out of a parking spot? Any noise made by turning the tires while standing still doesn't count.
The system will make noise if it is just a little bit low on fluid. Check the power steering fluid level. And by check, that means remove the cap, wipe the little dipstick, then reinsert it to measure the fluid level. If it's low, top it up. The car uses Pentosin CHF 11S fluid. It is expensive, but reasonably easy to find.
Old Dec 4, 2013 | 05:09 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
power steering pump is going bad.
Old Dec 4, 2013 | 05:29 PM
viz4575's Avatar
Thanks for the reply, the power steering flued seems good, I don't notice a leak any where in the system... I did however noticed that the squeaking stopped just after washing the car, I did spray water in the fender opening above the tire... It seems like whatever is making that noise got wet and it stopped temporary... But it came back
mb techman's Avatar
CLA45
Old Dec 4, 2013 | 07:08 PM
viz4575's Avatar
It sounds more like someone is really Geting it on a bed....may be a 4s or so...
Old Dec 4, 2013 | 07:25 PM
pcanuck's Avatar
2014 e63 amg,e46 m3
If it sounds like a hinge with no oil, or loud grinding, sure it is your ball joint.
Got mine replaced a month ago.
Good Luck.
Old Dec 5, 2013 | 09:48 AM
mb techman's Avatar
CLA45
Old Dec 5, 2013 | 11:38 AM
novae500's Avatar
W211
Had the creaking noise and replaced lower ball joints. Getting the noise again so have the upper ball joints that need to install.
Old Dec 5, 2013 | 12:54 PM
viz4575's Avatar
I did the lower ball joints like 2-3 months ago.... I'm afraid I didn't so it right...
Old Dec 5, 2013 | 08:46 PM
viz4575's Avatar
Here is a small video that I've made with the noise that it makes ...
Old Dec 5, 2013 | 08:57 PM
mb techman's Avatar
CLA45
Old Dec 5, 2013 | 10:23 PM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
Sounds like the R.M.S. Titanic, lol. My lower left ball joint is popping/clunking when turning or going over speed bumps. The seal is shot and I just squirt some oil on it once in a while to make it quiet again. Thinking about doing a complete front-end rebuild at 100K. I'd try spraying some Wurth HHS grease around the the front ball joint seams to see if that solves the issue. Please post the fix once you figure it out.
Old Dec 5, 2013 | 10:55 PM
viz4575's Avatar
Yeah lol titanic, I'm thinking of greasing them up with one of those grease guns, squeeze some grease in side the rubber booth ... Let u know tomorrow if it works
Old Dec 5, 2013 | 11:06 PM
mrweelr's Avatar
Anything to stop that noise, must be embarrassing. I have squealing belts and a knocking left ball joint when my car is cold. Feels like I'm driving a clunker around the parking garage at work when the car is cold. After it warms up, the sounds go away. Let us know how it goes.
Old Dec 6, 2013 | 11:37 AM
V TO E55's Avatar
05 E55/08 C6 Z06
Had that same exact sound on a few customers cars plus my car and and after changing out the ball joints it got worse and it turned out to be front lower control arm bushings..so now every customer that comes in we change both while we do the control arm bushing
Use that HD ball joints and the car drives better then new
Old Dec 31, 2015 | 10:29 PM
Lowflight's Avatar
2009 SL63 AMG
Originally Posted by viz4575
Here is a small video that I've made with the noise that it makes ... https://m.youtube.com/watch?v=jekCP8ipT8k
Mine has done that one day after driving six hours back from New Orleans. Now...it won't do it. Wth?
Old Jul 3, 2019 | 03:45 PM
epitaxial's Avatar
2007 E550
Sorry to bring up an old thread but my car is making the exact same noise and its driving me crazy! When you say lower control arm bushings are you talking about the silver thrust arms that connect from the knuckle to the frame?
