The mistery revealed...twincharging is possible!
Twin, did you try going with a stock crank pulley and running higher boost with the turbo since its more efficient than the SC?
What method are you using to supply oil to the turbo?
Do you have a pic of the entire trunk completed?
Appreciate your time and thanks for sharing your experience/information.
Beautiful build, the car sounds sick!!!
Let me know the next time you visit the track, I'd like to bring my son out to watch her run.
My 6 year is infatuated with fast Benz's (guess he takes after his old man).
2004 E55 AMG
Nice work. It really sounds sick breaking traction in this video: http://distilleryimage3.s3.amazonaws...1a89eb_101.mp4
#32
They do make kits for this through a company called Hellion but not for the AMG.
http://www.hellionpowersystems.com/
#33
SO BAD ***. To think, this has been attempted so many times with these cars. Next year, we DEF need to do a big Northeast gathering to check out these beasts
#34
PLATINUM SPONSOR
Great looking car and build!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#35
2004 E55 AMG
#39
2004 E55 AMG
#40
2014 cls63 a amg. 2018 AMG GTR
I see you are working on a Killer Chiller. Good choice especially for daily driving. 5 Gal rear tank is what I wish I had done instead of the 2.5 gal under hood. Still works great but could use a little more water. If you get that dialed enough you wont need Meth or E85.
Nice build
What was your user ID on CLGP ? Noticed you had a single t67 on your GP I had the original Cartuning kit which was only good for 400 WHP. Still hauled though.
Nice build
#41
2004 E55 AMG
Nice build
Nice build
My I'd on clubGP was 00blackGTP, I actually copied a zzp kit and fabed it myself, I made a custom 90mm plenum with a ls1 throttle body, 3"dp and exhaust, on 18lbs it def made over 450whp
#42
Thanks man, yeah the ice tank is great and the chiller I won't even hook up till summer, I like e85 more for its safety than anything and same with the meth+ a little added fuel, and if you purge it on start up it helps the cold start tremendously
#45
CTSV/6sp Grocery Getter
Wow, great looking setup!
In the "Turblo" video, am I the only one that hears what sounds like detonation at the 7-8, and 13 second part of the video?
Hopefully this was just not detonation and just the car shredding the pavement due to the massive amount of power being made now!
#50
2004 E55 AMG
PM me for pricing
