Can I use OIL EXTRACTOR on my E55 AMG?
Old Dec 28, 2013 | 02:18 PM
E55AMG05's Avatar
2005 E55 AMG
I want to change my oil but I don't want to go through the annoying hassle of rattling under the car and locating bolts and making crazy oily mess it just Annoying when filter is at the top!!! OK!!! I have a RED dipstick. It doesn't have the metal wire that feeds to the engine that calculates oil level it's just red and it sits by the AIR distributor of the engine. Can I insert the oil extractor through there? PLZ I NEED A ADVICE I WANT TO DO THIS STUFF MYSELF NO MORE STEALERSHIP!!!! WITH THERE FAKE SMILE OF JINGLE BELLS AND GIGGLES!!!!! as I swipe my CARD and leave with my keys and a TIPLE DIGIT PRICE RECEIPT!!!!!
Old Dec 28, 2013 | 02:43 PM
C3Duece's Avatar
2002 C32AMG
yes
Old Dec 28, 2013 | 10:07 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
You won't get to the bottom of the pan due to the oil baffling and will still have some old oil left in the car.
Quit being lazy and do the oil change correctly. Every 7.5k-10k miles is not that big of a hassle.
Old Dec 29, 2013 | 05:19 PM
Kropf's Avatar
2005 E55 Black, 2007 GL450 Carneol Red
... I have a RED dipstick. It doesn't have the metal wire that feeds to the engine that calculates oil level it's just red and it sits by the AIR distributor of the engine. Can I insert the oil extractor through there? ...
If it's the fill tube behind the rear of the engine with the red cap, you'll be sucking the transmission fluid out!!! (Not your engine oil!)
Last edited by Kropf; Dec 5, 2018 at 03:00 AM. Reason: To clarify that the tube with Red cap BEHIND the engine is for Transmission.
Old Dec 29, 2013 | 05:33 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Skip to post #12,
https://mbworld.org/forums/w211-amg/...hange-e55.html
Old Dec 30, 2013 | 09:54 AM
V12Godspeed's Avatar
Your worst nightmare...
Couldn't agree more, you have been an E55 owner for some time now! Time to get dirty . It's super simple and easy. If I was closer i'd give you a hand but I am in LI now.
What year is your E55? On my 04 I could do it with the extractor, with the 06 I have now my tech said to do it the right way, have to get underneath the car, remove both plugs and done. I'd say if you can, lift it up slightly, get the covers off and drop the car so it could drain all the oil then jack back up and put plugs in.
Old Dec 30, 2013 | 10:40 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
Originally Posted by Yacht Master
That's good to know, I used the extractor the first time I did it myself.
Where are the two drain plugs? Not sure I have come across 2 of them
Old Dec 30, 2013 | 11:41 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Mine only has 1 drain plug.
Old Dec 30, 2013 | 12:08 PM
55fanatic's Avatar
What differentiates the 2?(besides the extra drain plug)
Old Dec 30, 2013 | 03:38 PM
Ag, you might want to check again,
Here are some pics of the engine/pan scroll down like, 12 pics.
https://mbworld.org/forums/2183169-post28.html
And thanks again to Finny!!!
Old Jan 9, 2014 | 01:23 AM
E55AMG05's Avatar
2005 E55 AMG
Hey relax I am not lazy it's just 1. I don't want to remove the plugs from underneath because once you remove the plugs you have plug brand new ones back in. 2. Last it's a non messy job.
Old Jan 9, 2014 | 01:26 AM
E55AMG05's Avatar
2005 E55 AMG
Damn that's the timing chain and the whole cylinder block head. Nice timing chain replacement is no joke
Old Jan 9, 2014 | 01:44 AM
E55AMG05's Avatar
2005 E55 AMG
Originally Posted by Kropf
If it's the fill tube toward the rear of the engine with the red cap, you'll be sucking the transmission fluid out!!! (Not your engine oil!)
Actually no the dipstick for the transmission tube, is behind the left air duct. The dipstick for the engine oil is behind the the supercharger.
Old Jan 9, 2014 | 01:48 AM
E55AMG05's Avatar
2005 E55 AMG
Thanks I appreciate it has been sometime i have been a E55 owner for almost 4 years. Mine is a 05 and the red dipstick for the engine is behind the supercharger. the dipstick for the transmission tube, is behind the left air duct
