E-brake does not hold the car
Old Jan 1, 2014 | 04:00 PM
dbworld4k's Avatar
BMW M5 + E55 AMG
Pedal is depressed without much resistance and the light goes on, but the car freely rolls in neutral.
Is this a simple fix with "tightening the cables," or is something more extensive at work?
Thanks for any help!
Old Jan 1, 2014 | 04:18 PM
3BNick's Avatar
2006 E55
You should remove the rear calipers and rotors and inspect the linings and hardware for the parking brake shoes. Also make sure the cable is attached to the brake actuator in the brake shoe mechanism. The parking brake on our cars are a drum in hat system meaning all friction for the park brake is inside the hat of the rear rotors. If the rotor comes off on the rear with very little or no drag or resistance, you may need to adjust the ahoes. There will be an adjuster wheel in the hardware you can turn to expand the shoes to take up the slack you are experiencing.
Old Jan 1, 2014 | 06:01 PM
dbworld4k's Avatar
BMW M5 + E55 AMG
Interesting. Thanks for your input.
The rear brakes were replaced just before I bought the car so something was probably not tidied up properly back there.
Old Jan 2, 2014 | 06:03 PM
regor60's Avatar
06 E55 Black
This feature only works when the car is in C mode and brake initially pressed firmly
Old Jan 2, 2014 | 10:38 PM
FromM3toAMG's Avatar
07 E63
Cant the E break be adjusted? i was having the same issue, last time i had my car in for service they adjusted mine.
Old Jan 6, 2014 | 11:54 AM
jnash's Avatar
2017 S63
you will need a tool light this to set the springs for the shoe replacement
http://www.ebay.com/itm/Mercedes-Ben...-/251418243866
Old Jan 6, 2014 | 12:09 PM
dbworld4k's Avatar
BMW M5 + E55 AMG
True. But the e-brake pedal being freely and easily depressed without any resistance can't be right...
Old Jan 6, 2014 | 01:19 PM
jnash's Avatar
2017 S63
well, mine did the same. On inspection of the brake shoes, the material had completely worn off/broke away from the shoe itself leaving no friction. Of course it could be the cable but I doubt it. You really need to take it apart and see whats going on.
