FS: Eurocharged 82mm TB & Adapter Plate
FS: Brand new EC 82mm TB & Adapter plate. Includes bolts that came with the kit, you will need to port your S/C inlet (snout) to match the adapter plate and do a simple pin swap as documented in the Eurocharged instructions. Price is $500 + shipping to CONTUS.
![](http://i1273.photobucket.com/albums/y406/jdonavich/20140102_190200_zps898c7a2a.jpg)
![](http://i1273.photobucket.com/albums/y406/jdonavich/20140102_190302_zpsac77a84b.jpg)
![](http://i1273.photobucket.com/albums/y406/jdonavich/20140102_190248_zpsa2051604.jpg)
![](http://i1273.photobucket.com/albums/y406/jdonavich/20140102_190214_zpsf8011b04.jpg)
![](http://i1273.photobucket.com/albums/y406/jdonavich/20140102_190331_zps16cf8e61.jpg)
Hey Vazha - It means you need to bore/port your S/C inlet to 82mm to match the Eurocharged adapter plate and 82mm TB. This is the 82mm TB that Eurocharged sells with their kit, I'm only selling the TB, adapter plate and bolts.
http://www.eurocharged.com/products/...ade-kit-detail
Price drop $450 shipped. Brand new 82mm throttle body and adapter plate.
It's not the complete kit, just the TB and adapter plate, as depicted in the pics. You will need the rubber intake hose and porting/boring done to your S/C inlet (snout).
Price drop to $425 shipped
Blown 208 55 amg, 211 55 amg
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
oh and cant forget the diffuser from suvneer and lowering links
TB is still available as of today...
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
I wonder how the showed Part Number at the plastic side cover, can be a 82mm TB?
My MB 82mm has a 273 Part Number IIRC.
Anyway, very attractive price now :-)
A throttle body with a part number 273 is also possibly (or more likely) intended for the 5.5 liter E550/CLS550/S550/SL550 Double overhead cam engine series. There are a number of threads describing the required modifications to the inlet system to use a 273 throttle body on a 5.5K engine.
The 113 prefix means that the throttle body for sale here appears to always intended for the SOHC 5.0/5.5 engine. Perhaps it was modified by Eurocharged?
2014 cls63 a amg. 2018 AMG GTR
I have the EC 82MM kit and have no issues at all. As others have said it seems to be more tune related. That price is dirt cheap too for those of you who dont know any better. This will save you many hundreds of dollars.
So, if I have a completely stock 2006 and I get this, I also need to get a CAI for an 82 (or the y adapter somewhere), as well as port the supercharger intake? Is this the only way this setup is ever done... meaning everyone has to port if they move to a 82?
I remember when I put my 80mm TB kit on I didn't have to do any porting whatsoever... think it came with the ported inlet.
So the eurocharged kit comes with the inlet in question, and I'm betting you can't buy it easily separately... have I got this straight?
I don't mean to crap on this thread, I initially saw the Mercedes part number and was going to tell OP to raise his price if it is a new 82mm Mercedes TB, then it is definitely worth more.
However, the part number on the TB 1131410125 is a Mercedes part number (even has the Mercedes logo - unless Bosch puts Mercedes logos on everything) and does not appear to be a 82mm TB. Please double check it. I have heard that it is possible to switch some parts out from other Mercedes TB with the Audi TB to make it plug and play and that's what may have happened here. All I can say is that the PN shown in the pic is not 82mm. They are used in 3.0 and 3.5L engine cars GLK350 and C300. Google search and search on Mercedes parts sites show this
This is an 82mm throttle body from Eurocharged. From what I understand, they bore/modify a new Audi 78 or 80mm TB to 82mm, so looking up MB part numbers is only going to create confusion. If you need specifics about this TB and adapter plate, contact Jerry or Adam at Eurocharged since they make it. The parts are brand new and have never been installed. The other parts you'll need to install this are the S/C intake snout/plenum, rubber y-adapter and gaskets from the dealer as the blower has to come off for installation.
Hope this helps
Hope this helps
