Eliminating secondary cats, how does the sound change?
I just secured E63 mufflers and will be installing soon on an otherwise completely stock exhaust. I may end up changing the mufflers and leaving it at that, but i'm entertaining the idea of opening up the system a bit more.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I listened to this 55 with mufflers only and really like the sound -
To me, having both removed makes it a bit too loud and raspy for my taste. I was thinking removing the secondaries only might give some extra volume/throatiness without losing the deep tone. It seems to me the resonator is there to smooth the sound out and eliminate the rasp.
