e55 spark plugs!one step colder ngk?
Old Jan 19, 2014 | 09:28 AM
aggi78's Avatar
2003 e55
Does anyone use ngk lfr7 colder plugs on stock e55? How dies the car perform? I leave in michigan where is pretty hot in the summer and pretty cold winters.what do you guys think?
Old Jan 19, 2014 | 10:01 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Just installed a set of NGK's (one step colder) in my CLS. The ones I removed were decent-poor in condition.
Car idles smoother and there's no indication that the car doesn't like the colder plugs.
Old Jan 19, 2014 | 10:58 AM
aggi78's Avatar
2003 e55
Thank you tech-tune.they say fir every 75 extra hp go one step colder on the plugs.im just wondering how the car will perform in cold weather specially on start..
Old Jan 19, 2014 | 10:59 AM
aggi78's Avatar
2003 e55
So far i kept my car stock and i boght the lfr7 colder plugs.before i put them in i was debating if i should still go with the iriginals lfr6
Old Jan 19, 2014 | 11:45 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
I don't think its a good idea... its cold as hell outside right now
Old Jan 19, 2014 | 12:47 PM
aggi78's Avatar
2003 e55
We had the -36F feel last week.crazy storm.it usually stays around 10F. if that happens again i am wondering if it will affect the running with colder plugs.will the engine stay colder than regular running temperature?
Old Jan 19, 2014 | 01:21 PM
Toadster's Avatar
2005 E55 AMG
love mine - smoothed out the idle a bit too - but I have the S/C pulley and tune (check my sig for a link)
Old Jan 19, 2014 | 01:28 PM
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Any thoughts on changing wires at the same time? Some people say yes, some people say it's not necessary unless they are bad...
Any advice here?
Old Jan 19, 2014 | 01:37 PM
Toadster's Avatar
2005 E55 AMG
Any advice here?
I didn't do wires, they tested out ok - but it's a quick/simple check
Old Jan 19, 2014 | 03:07 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Interesting topic,
are there any sideffects, especially for non-spirited daily driving mode?
Thanks alot :-)
Old Jan 19, 2014 | 03:26 PM
Toadster's Avatar
2005 E55 AMG
Originally Posted by Crissus
Interesting topic,
Thanks alot :-)
i daily drive - but then again a little modded
Old Jan 19, 2014 | 03:48 PM
aggi78's Avatar
2003 e55
No necessary to change the wires.they dnt really go bad unless the coil on top craks for some reason.they are not even listed on a manual as things to change for mantenace reasons. spark plugs need to be changed every 100k miles by the book.but in alot of cases way earlier than that.they make a difference.
Old Jan 19, 2014 | 03:58 PM
Bigtickets's Avatar
I've got a track day on friday and want to get the plugs done before then. I assume the gaping on the colder plugs is the same as the OEM plugs??
Old Jan 19, 2014 | 04:13 PM
aggi78's Avatar
2003 e55
I think the originals are 0.39" but the ngk plugs are pregaped you dnt have to mess with that.
Old Jan 19, 2014 | 04:15 PM
aggi78's Avatar
2003 e55
The colder might be 0.32 but they are perfectly gaped fo the colder run.i didnt checked mine for gap size.
Old Jan 19, 2014 | 04:16 PM
aggi78's Avatar
2003 e55
Anyone else running ngk lfr7 colder plugs on stick car? Hiw is your car running?
Old Jan 19, 2014 | 07:23 PM
Tech-Tune's Avatar
I wouldnt be too concerned with only one step colder. If it were two or three steps colder I'd probably second guess it as well, but one step colder is not that much of a difference.
Go for it.
Old Jan 19, 2014 | 09:48 PM
aggi78's Avatar
2003 e55
Thank you i think i will install the one step colder plugs
Old Jan 20, 2014 | 03:38 PM
Bigtickets's Avatar
+1
Old Jan 30, 2014 | 01:14 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Sorry if I have missed it....
can someone confirm the correct NGK number for the one step colder plugs? Thanks...
Old Jan 30, 2014 | 02:26 PM
Bigtickets's Avatar
Try this link for the part.
http://api.viglink.com/api/click?for...39110984550310
Old Jan 30, 2014 | 06:11 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
FWIW The SLR uses ILFR6A or LFR6AIX-11 NGK. Note, these are 6 series heat range. NGK's have a very wide heat range.
Old Jan 31, 2014 | 09:35 AM
aggi78's Avatar
2003 e55
Ngk one step colder plugs are: lfr7 aix part nr #2309
Old Jan 31, 2014 | 12:56 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Where in MI are you located? I've only seen one other 55 on the road. Also, you're driving it now? I couldn't get out of my sub in March last year, lol, mine's been parked since November.
Old Jan 31, 2014 | 02:16 PM
berti_00's Avatar
2016 Cls63s AMG
damm i had a website were i bought mine and alot of members here did too but i just dont remember it anymore :/ they were like 98 bucks shipped for all 16
