Looks like another blown 55 motor
Old 01-27-2014, 06:57 AM
chawkins2001's Avatar
2006 E55 AMG
Hey brotha, saw you called last night. Don't worry just yet, and if you get that code pulled, that will help alot. Getting an esp malfunction leads me to think otherwise besides a hurt motor. I have seen that happen a few times. Typically it comes back to a tune issue. Did you have any leaks or smoke out the exhaust?
Old 01-27-2014, 09:11 AM
Manuyc's Avatar
06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
MAf IMO could go faulty and give a esp light
Old 01-27-2014, 09:15 AM
Joncl's Avatar
E55
These cars don't have maf only map sensor
Old 01-27-2014, 10:37 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Good luck and another way to check the engine real quick , is to open the oil cap while engine is running and if a lot of smoke is coming out, then you have blow by.
Sounds like with no oil coming out anywhere, no smoke from rear pipes or steam, that you may have another issues that could be minor.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 01-27-2014, 11:13 AM
Forrest Gump 9's Avatar
shrimp boat
Probably a coil took a dump on you, but if the engine blow, you can swap this in
http://www.ebay.com/itm/Chevrolet-Performance-19260164-Cadillac-LSA-CTS-V-Engine-/111064451822?pt=Motors_Car_Truck_Parts_Accessories&hash=item19dbf50aee&vxp=mtr
Old 01-27-2014, 01:22 PM
Roverron's Avatar
ML63
It was TB issue all fixed 4 now!
Old 01-27-2014, 01:40 PM
  #32
Joncl's Avatar
E55
Hey brother can you elaborate? What happened ? That is really strange but if was just that happy for you!
Old 01-27-2014, 01:52 PM
  #33
Roverron's Avatar
ML63
Gasket was sucked in and was causing TB to reset I guess would be a simple way to put it so the car was surging like a miss. The esp light was the TB fault I scanned with SDS to find problem I'm glad I went back in the. Light or I might have ran the car and had that thing go all the way down in there
Old 01-27-2014, 02:05 PM
  #34
mertd93's Avatar
04 E55 B07
Good news, glad it was a simple issue!!
Old 01-27-2014, 02:28 PM
  #35
kompressede's Avatar
Sold - 05' E55
Who did your first tune, and who's do you have now?
Old 01-27-2014, 02:47 PM
  #36
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Isn't that a steel gasket ?
Old 01-27-2014, 02:53 PM
  #37
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
it is a rubber gasket that goes on the intake Y pipe. this gasket getting sucked in is a common problem I have seen it happen before.
Old 01-27-2014, 03:58 PM
  #38
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
Good outcome!
Old 01-27-2014, 04:46 PM
  #39
jcjmw's Avatar
2005 E55 Wagon
Alright! Great news!
Old 01-27-2014, 07:06 PM
  #40
berti_00's Avatar
2016 Cls63s AMG
Hey remember when this happened ones to me and I called you I was freaking out and than you picked up and told me go look there lol and low and be hold the friken rubber was half in there... Def was a scary moment but Thx to shardul I found it right away and went bought a new seal and done..
Old 01-27-2014, 07:19 PM
  #41
Roverron's Avatar
ML63
Yes not a good feeling what gasket did u buy?
And thanks for all the support from guys on here.
Old 01-27-2014, 07:27 PM
  #42
berti_00's Avatar
2016 Cls63s AMG
this was all when i had the STOCK air intake and the stock 74mm T/B so go figure and now i have everything upgraded and bigger and is perfect. I just ended up going and getting a stock rubber for the 74mm and slapped it back on and it was fine but yahh it was pretty scary because the butterfly on the TB was staying open and the car would rev up so shardul pointed me to that direction the first thing i go remove the airboxes look in and boom there is the stupid rubber piece in there cought... i took it out car was back to normal perfect and just added a new seal
Old 01-28-2014, 10:29 AM
  #43
PLATINUM SPONSOR
2003 CL55
Good news and I have seen that happen a few times on the dyno before.
__________________
www.ultimatepd.com
Old 01-29-2014, 04:39 AM
  #44
Celicasaur's Avatar
W212 - E63 AMG
Similar thing happened to me one time too (stock motor) but the ESP light didn't come on. I asked around on here and one of the chaps (I think a guy with a greeny corvette) suggested I look at that vacuum area by the TB and that was actually the problem too.
The misfire itself is quite spooky though and enough to make you upset until it's fixed. I defo didn't think it was a blown engine though. I've sadly got too much experience of those in other cars to know exactly what that's like.
Old 01-29-2014, 08:44 AM
  #45
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Yeah … I was going to post about being pessimistic. Always get it on a DAS and pull whatever codes/tests you can. Glad it was something simple for you.
By the way does anyone have a spare 82mm TB gasket or part number for it? I need one
Old 01-29-2014, 09:06 AM
  #46
Joncl's Avatar
E55
82mm t/b gasket: 2731410680- 14.61 retail
-s/c inlet gasket: 1131410780- 13.78 retail
Old 01-29-2014, 09:07 AM
  #47
turbo97se's Avatar
Awesome! .. are either of these the black rubber gasket that goes on to the plastic y-pipe?
Edit … just checked, seems like neither of these are the one I am looking for. I am looking for the one that goes between TB and plastic y-pipe. The one you need to turn inside out when retrofitting 82mm.
Old 01-29-2014, 09:12 AM
  #48
Joncl's Avatar
E55
No bud, sorry
Old 01-29-2014, 06:48 PM
  #49
60nomad's Avatar
2011 CTSV auto, 06 E55 white pano, 87 Grand national, 63 split window
I just read this whole thread and I was getting scared for you knowing what these engines cost to buy or rebuild and the work involved. I am glad that it was something so simple!
Old 01-29-2014, 07:26 PM
  #50
mertd93's Avatar
04 E55 B07
113 141 15 80
Quick Reply: Looks like another blown 55 motor
