Looks like another blown 55 motor
Was getting on ramp and started to accelerate up too 75
the ESP malfunction came on and I pull over
car was bogging down and coughing
I turned it off let it sit and then I started it again and the same thing of a hard miss
the dash say ESP malfunction and a solid CEL
If you can, find a way to pull the codes. That will give you a better idea of what is going on. If, if it is a blown motor, take a deep breath and remember it is just an engine and it can be replaced, as many of us here have. I wish you luck that it is something simple.
Im at home now
I will go back in the daylight its in the 20's and dark
yea im thinking its not looking good for me.. I don't even think I was doing 80 all I know is it got a little squrily and I started to get out of it then ESP malfunction and I start to pullover then notice tranny wasn't acting right stopped car put it in park and it felt like a hard miss. turned car off sat then tried to restart it and the miss was there. I called home for a ride let car sit 8 to 10 mins try to re start and same thing with miss and ESP light.
BMW M5 + E55 AMG
You experienced a misfire, which is one of the most common occurrences on any car. It could be MANY things - from a bad coil pack, vacuum leak, or a blown motor - and anything in between. No need to panic right off the bat. Get the codes read and go from there. I think you guys in the US have AutoZone that will give you readouts of the faults stored in your car for free.
I have SDS so I'll get the codes
just unusual that while I was getting on highway rear end get wobble the. ESP malfunction and loss of power and no transmission then misfire and then CEL
I'm sure it's either minor or major not good
I don't think it's a vacuum leak to hard of a mis
I think chawkins had something like this happen at the track and was an easy fix but I'm sure im
not that lucky
My fingers are crossed though
not that lucky
Yeah maybe we're overreacting and hope it's nothing major but you know your car better than anyone and it's doing too many weird things at the same time and sadly that's the first thing that goes through anybody's mind that owns a 55k unfortunately.
My map sensor did that to me twice ,had bad miss and throttle/ trans acted all messed up,good luck,looked at diagram it's b28 charge air pressure sensor,
