Weird SDS issue when changing country
I decided to change my country from US to get rid if the annoying keyless go chime but I also didn't want to lose the side marker lights, so instead of changing to ROW I set it to Canada. The keyless go chime was gone and my marker lights still worked but I got an immediate ESP malfunction as soon as I put the car in a forward gear upon every start-up. Obviously having ESP is more important than getting rid of that annoying chime so I switched back to US. If that wasn't weird enough, ESP went back to normal but the chime is still gone!
Obviously I'm happy with the results but I'd still like to know why this happened. Anyone have any input to share?
I Definitely hit F3 to save the changes and it showed Canada when I went back in to set it back to US. The fact that the keyless go chime was removed tells me it also save the Canada setting but I still can't figure out why the chime didn't come back when I set it back to US.
Check if Keyless Go is present in CGW. If it is set to not present, the chime will not be there. The keyless go still functions though
![](http://i39.tinypic.com/5k3ew0.png)
Keep in mind, the ONLY settings I originally changed was the country.
