Help! I cant close the trunk
Old Feb 2, 2014 | 08:17 PM
Xattica's Avatar
2016 AMG GTS Stage 3
Help!!!
Is like the latch is stuck on open position. How I can close the trunk manually or in any way??? Lost here.
Thanks!
Old Feb 2, 2014 | 09:20 PM
Ryangerritsen's Avatar
05 E55 AMG
Have you applied lubricant ? Or used your key in trunk to activate solenoid? Sometimes a flick of a flat head screwdriver in the latch can free it up.
Old Feb 2, 2014 | 09:42 PM
Xattica's Avatar
Lubricant where?
Looks how is the latch
Is in the open position.
I used the mechanical key and nothing. Also I pushed the latch with a screwdriver and nothing. I can hear the mechanism if I press the fob, from inside of the car, the emergency button, etc. But the latch doesn't moves.
Old Feb 3, 2014 | 10:13 AM
Xattica's Avatar
Help!!!!!!
Old Feb 3, 2014 | 10:57 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
has the cable snapped or is the latch just stuck?
Old Feb 3, 2014 | 11:48 AM
viren.89's Avatar
2004 E55 AMG
Does the latch move when you try to do it with the hand ?
It'll go back and won't come back if the cable has snapped.
Old Feb 3, 2014 | 11:52 AM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
From your 1st pic, you see the small hole that is created by the latch and the metal cover (right at the middle of the pic)? Put a small screw driver in there, pull it down, it should pop right out and it should be close-able again. GL
Old Feb 3, 2014 | 02:50 PM
Xattica's Avatar
Cable looks good. I can press the latch (up) and the spring works punching the latch to the original position. But when I tried to close the hood the latch didn't close. The hood stay opens.
This is what happens
Old Feb 3, 2014 | 03:40 PM
CLKCLK's Avatar
If it happens exact in the vid, from the second pic, release the 2 bolts a bit to adjust the latch. Move the latch up a bit. GL
Old Feb 3, 2014 | 05:40 PM
Xattica's Avatar
Exacts as the video. I adjusted to the up (maximum) and nothing.
Old Feb 3, 2014 | 06:07 PM
Xattica's Avatar
That's a locking pin???
Old Feb 3, 2014 | 07:13 PM
Xattica's Avatar
If this latch is normally close and is a mechanical part, looks like there are no locking ping or any other mechanical part to complete the locking... really don't know. The part can be damaged? The opening (electronics) looks good, using any bottom (fog, trunk or driver side).
Old Feb 3, 2014 | 07:32 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Can you do this? Made this vid just for you
Old Feb 3, 2014 | 09:07 PM
Xattica's Avatar
Lovely!
No, cant do that. The latch don't locks likes that. I press it, but get back to open position by itself. Never locks.
Old Feb 3, 2014 | 09:26 PM
turbo97se's Avatar
Either your release cable is stuck open or the catch is broken. Can you hear a click from the trunk when you press the button for trunk release?
Either way, you probably need to strip the trunk trim to see what's going on. Picture #12 gives you a rough idea of how to strip the trim.
https://mbworld.org/forums/5752372-post2.html
Lovely!
Old Feb 4, 2014 | 05:55 AM
Xattica's Avatar
Thanks.
Yes I can hear the click when press the button for trunk release. Also I can see the gears working trying to open the latch. But is on open all the time. Maybe is time to buy a new latch (A1717500185 / A1717500085)?
Old Feb 4, 2014 | 08:17 AM
turbo97se's Avatar
Have you removed the latch? Try that first to see if something got stuck.
A1717500085 is likely the one you want. If you have code 884 (additional lock) in your data card then it is the other one. Can't tell without a VIN. You can physically tell if you have the additional parts around it also … for example part 120 in the pic. If you have that then it is A1717500185.
Old Feb 4, 2014 | 11:32 AM
Xattica's Avatar
Well, I removed the latch, but don't routed the mechanical cord.
I will strip the trunk trim to see what's going on.
Old Feb 4, 2014 | 11:50 AM
turbo97se's Avatar
and ...? Not sure I understand. Does the latch lock when removed? If not, then time for new part
Old Feb 4, 2014 | 12:06 PM
Xattica's Avatar
No, the latch never locks. Is like to be on open mode for ever. All works but on open position. I can hear and see the latch gears trying to open the mechanism, but is open already.
Old Feb 4, 2014 | 12:08 PM
APBTdogman's Avatar
05' E55 - 22' Jailbreak Hellcat OTW
Having a broken latch in the trunk open position is 1000% better than the latch failing in the trunk closed position.
Old Feb 4, 2014 | 01:03 PM
Xattica's Avatar
Well!!!! In close position you can drive the car. Right now I can't!
Old Feb 4, 2014 | 02:27 PM
CLKCLK's Avatar
Ziptight or super glue should work lol jk
Old Feb 4, 2014 | 04:55 PM
Xattica's Avatar
LOL!
A $120K car with a ziptie. Well I drove it for 100 miles with an audio cable hanging in the trunk...
Old Feb 4, 2014 | 05:29 PM
Xattica's Avatar
This is amazing! I used a piece of tin carton between the latch and the metal piece to maintain the trunk close during the night. Now I can't open the trunk!!!!
