How to separate intercooler from the supercharger?
I'm trying to separate the intercooler from the supercharger.
I have already removed the 4 bottom bolts and the two front bolts but I cannot get the supercharger unstuck from the intercooler!
I read one post that said to use a rubber hammer on the side but I still couldn't get it apart.
I was thinking maybe stick a thin putty knife between the gasket material? Thanks
On the side of the intercooler? Thanks for the replies!!
I'm hitting pretty hard right in the side with a rubber hammer but nothing is moving
How hard shouldn't I hit? I'm swinging with pretty good force but I'm not trying to "hit a home run"
You're using a rubber hammer against metal, you can basically hit it as hard as you want
