Audio Gateway removal and replace....
sigh...it didn't work..still the same...start car, music plays then poof its gone after 5 mins. bluetooth/cdc not found. just the whinny ground sound.
, because if I connect the AGW fuse 6 in the trunk, the car starts draining the battery, also when the fuse is connected, I can see the MB logo, and sometimes the initial screen with radio sound before it shuts off. I think the fiber optic cable is damaged as per your conclusion. The only thing I noticed before the radio stopped working, that there was a minor leak in the trunk from the left side, the leak was from the airevent and I sealed it. But this minor leak was causing a humidity in the trunk, and as you know many fuses and cables are in the back, and they don’t like humidity, maybe this damages the cable.
. I would like to try the head unit, but unfortunately i am afraid that i can't take off the head unit, i don't know how to do that and have a concern to break something in the dash. Reading your respond to the ML, remembered that the star told me that the AGW start's working for seconds then getting overheated and shut off, that's why he recommends to replace it. does this make sense
, battery drains, no radio. the part number of the two was matching the original one. when i went to the star, my original AGW was on the car. so i have tried 2 already with no result. that's why i am thinking that the problem is in the fiber optic cable, but what make me crazy, how the cable would go faulty
, that i have only the AGW and the Radio and still cant figure out the problem, although with star help
... really i dont know what to do, seriously thinking to sell the car, but who will buy? no radio and no mileage on it
zy:. i love the car, but without radio its sucks. i already bought the fiber optic bypass, but as you mentioned, i have nothing to bypass.
.. also i noticed that i have to remove fuse 6 from the trunk (AGW) and fuse28 from the interior (Radio) to stop the battery drain, i have to remove both? i tried to remove only 6 in the trunk but the battery still drains, i have to remove number 28 as well, any thought why both should be taking out to stop the drain. Thank you my fried for your time and the valuable advises.
A211827"46"42.....
my unit part number is different at the quotes. your part is "43" and my unit is "46" only means my unit is newer than yours, not by much tho. no fan on my unit either.
look, whenever somethings not right, we all want to get rid of our cars and get something that is newer and no problems but eventually if you keep your car long enough, surely, you will have a problem!!! don't give up just yet, this is a very minor problem and one that i think you can fix and i promise you, You will feel so pumped and glad when you DO fix it!!! these cars are very sensitive and funny with the connectors/airbags/seats etc etc etc....
let me share my experience i had just this past week. did my oil change due to its been over a year and although i only drove the car 3k miles, i dont like the synthetic oil to be in the car for more than 1 year or 10k miles max. so when changing the oil, the front of car had to be placed on jackstands and the oil done. afterwards, going for a test drive the car symbol came on my car with the up arrow and message "VISIT WORKSHOP" as if to say that the airmatic pump is not working or malfunctioning???? of course i was disturbed! all i did was change the oil???? got my STAR and it said something about the right Accelerometer Sensor fault?? knowing what i know about these cars, i just took the connector off, blew some air into it and reconnected it and made sure it was a firm connection, and BAM: no more faults, no arrow, no VISIT WORKSHOP message!!!! damn thing was fixed or better yet, problem solved!! sometimes it is as simple as that. hang in there and at worse, you will have learned something about your car and more you know and do, more comfortable you become with the Mercedes Brand and all its quirks and weird happenings!! let me know what/how you want to proceed. take care.
I have a rather simple question, regarding battery drain due to possible issues with the AGW. Background - 2003 E500 with Harmon Kardon 6-CD changer and tape unit. Radio works fine. But I've had battery drain twice in the last few months. SRS light is 'on' (following replacing the main battery in September). The AGW scenario sounds logical, if it's not shutting off (or coming on by itself) and running the battery down eventually.
My question - removing fuses #6 and #28 will cut power to the radio totally, correct? There's no way to bypass the AGW and have the radio function (since it's a fiber loop), right? Having not seen the fuse-box layout, can the fuses be moved on the fuse board to only be key-dependent? I know with the cigarette lighter fuse, you can place it in different slots on the fuse line, to make it have 'constant power' or have it be 'key-dependent'. Is this possible with either/both of these two fuses (6 & 28)?? If it is, that would resolve the battery drain issue.
Thanks again for the info provided here!!!
