No more dead body in the trunk, thanks Shardul!
Old Mar 2, 2014 | 12:31 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
That dreaded dead body noise from the trunk visited my new E. After making sure my subframe mounts were still intact that left me with the next logical suspect, the rear shock. Shardul assured me that it was the culprit if the subframe looked good and was able to send me a good pulled OEM shock for a fair price. Installation was easy and no more thumps from the trunk over bumps (geez, I should write for Dr. Seuss!).
Thanks buddy!
Old Mar 2, 2014 | 12:49 AM
GunMoto's Avatar
EG8 | E46 | W211
Nice!!
Old Mar 2, 2014 | 04:34 AM
ss.dna02's Avatar
05 E55 AMG
I have this noise going over bumps. I thought it was normal. So its just the shock ?
Old Mar 2, 2014 | 09:05 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Thanks glad to help !
Old Mar 2, 2014 | 09:49 AM
dbworld4k's Avatar
BMW M5 + E55 AMG
I get these, too. Thought it was normal.
Old Mar 2, 2014 | 11:51 AM
chiromikey's Avatar
It's definitely not normal but our air springs mask most of the normal compression and rebound symptoms of a bad shock. Get underneath or remove the wheel and first make sure the subframe mounts are intact. If they are, take a look at the shock to see if there are any signs of oil leaking. If so, then you know it's a bad shock. Here's how my shock looked...
Old Mar 2, 2014 | 03:13 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Good to see you back in the game!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 2, 2014 | 09:52 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Shardul is the man, glad to see he was able to help you out with an inexpensive fix.
Old Mar 2, 2014 | 11:06 PM
cm60k's Avatar
+100000000..
ZAYED,,
