Anyone have a STAR unit I can rent?
Old Mar 18, 2014 | 09:45 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I got the white "BRAKE! visit workshop" message and it's not showing a code with my OBD scanner. I want to see if it shows up on SDS.
I considered buying one, but I know it won't really get much use.
If someone is willing to rent one to me, I'd be grateful.
Thanks!
Old Mar 18, 2014 | 09:52 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
If you have a multimeter, you could try ohming out the brake pedal switch. This is a common fault and does not throw CEL.
Old Mar 18, 2014 | 10:16 AM
BagMan's Avatar
Thanks, but I replaced the brake pedal switch and the warning remains.
Old Mar 18, 2014 | 11:15 AM
turbo97se's Avatar
The other small thing you can check is that the pad that presses the brake switch is physically present.
Looks like you have Keyless go. What happens when you press the start button with and without the brake pedal pressed? Do the brake lights come on and off when you press and release the brake pedal?
Looks like you are heading down the right path of asking for SDS help .. just trying to help you out diagnosing a little more until you can get your hands on one.
Old Mar 18, 2014 | 11:27 AM
BagMan's Avatar
I certainly appreciate the help! I'll have to check these things out when I get home tonight.
Old Mar 18, 2014 | 11:48 AM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Shardul on here rents them out if i recall. Good luck.
Old Mar 30, 2014 | 10:16 PM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Can't help you with a rental - but my light was caused by a broken connection to the sensor as someone else said. Check that first.
Old Mar 31, 2014 | 12:45 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I'm not into renting mine out, but if youre ever in Orlando you can use it free of charge.
Old Mar 31, 2014 | 04:53 AM
moosejaw's Avatar
none
Could be your aux battery
It powers your SBC
You get the error convienence features not available?
Old Mar 31, 2014 | 10:08 AM
BagMan's Avatar
Thanks guys. I brought it to the dealer and they said it just needed to be reprogrammed.
I'd still like to get my hands on a SDS for a weekend to do a few minor things.
