Crazy cheap MAP Sensors!
CLS55 AMG, ML63 AMG, Cayenne S
I was looking for a MAP Sensor for my CLS55, which I figured is the same as the E55, OEM PART "Mercedes Benz Boost Pressure Sensor" # 0051537228, which cheapest I saw it was $50 on ebay.
Now, this sensor is made by BOSCH, part # 0261230191, double checked on google and it's the same part, only missing the MB logo, found as low as $16.84! , here http://www.davesdiscountautoparts.co...sch/0261230191
Please confirm on your own too, but I am pretty sure it's the same part, and that is a heck of a deal for a part that would cost $90+ at the dealer.
femre (02-15-2017)
00 C200 & 00 C55 & 06 SLK55
The picture from that site not shows if it Bosch unit or not..!?!,
MB has "3" different #s, "006 153 16 28" & "006 153 98 28" & "007 153 00 28", with same shape & same connector plug, can those be used in M113K...??
http://www.ebay.com/itm/Bosch-026123...-/191036180826
ZAYED,,
ZAYED,,
I would advice against using anything but OEM Map Sensor! If you go with aftermarket your fail probability is higher, and replacing that b.e.a.c.h. is NOT fun! You do not want to be doing this two times.
DC "better" than BOSCH?, I don't think I would go that far, but these MAP sensors seem to be a weak link.
ZAYED,,
ZAYED,,
