S/C Pulley install Guidance regarding Shims
Old 05-06-2014 | 11:06 AM
testknight's Avatar
CLS55
All,
I must not be finding the right threads in my search, not using right terms or now wondering if it was in a thread I found but perhaps didn't read it all the way through so missed it, but just need to ask:
What is the guidance on determining how many, if any, shims are required during S/C pulley install? Anything else to consider aside from a stock install procedure?
I actually couldn't even find instructions for the install anywhere, which I assumed would discuss this. I decided to let my Indy do the install, so just want to pass them this info.
Old 05-06-2014 | 11:22 AM
berti_00's Avatar
2016 Cls63s AMG
There is instructions I have some ill post for you
Old 05-06-2014 | 11:24 AM
berti_00's Avatar
2016 Cls63s AMG
if anyone is interested on knowing how to remove or add a pulley here is a little method... ( i cant believe i took my car to the dealer to do this )
anyways
Steps..
For those worried about scraching your clutch like me lol wrap it with tape twice you'll be good.
1. First get the tensioner lose and remove the belt off
2. Get two clams big enough to wrap around the clutch
3. put both of them on and offset them by a little so they hit on the engine cover holder pieces (also wrapped with tape)
4.grab a wrench and take the damm bolt off.
easiest job ever
When you put it back together just reverse the claps and bolt it on put some Teflon tape on or locktite w.e
Old 05-06-2014 | 11:26 AM
novae500's Avatar
W211
use all shims for the s/c pulley.
Old 05-06-2014 | 11:44 AM
testknight's Avatar
CLS55
hmm, yeah doesn't look too hard (hell I did my own crank pulley on my old C32). I guess I was hesitant more because of a couple posts by folks who said that had hell of a time getting pulley off or couldn't get it off at all (fear making things worse).
Nice directions though...I think you are selling me on doing it myself...thanks. Would you remember how much tourque used to put it on or did you just crank it on there? Were you using std breaker bar?
Shardul emailed me cleaence specs .35-.45mm
Old 05-06-2014 | 12:01 PM
berti_00's Avatar
2016 Cls63s AMG
its silly easy. You can have it off in less than 10 minutes.
Old 05-06-2014 | 12:37 PM
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
Also been searching through past entries for this, thanks for the additional info berti_00. If all we are doing is pressing a new bearing onto the stock s/c pulley, no additional shims are needed? the .35-.45mm clearance is between the s/c clutch and the pulley itself?
Old 05-06-2014 | 01:08 PM
schnell!'s Avatar
'04 E55 AMG, '03 ML500, ‘13 BMW 528i
I recently did this myself.. pulled the stock pulley off to try and cure the chirp on engagement. Used the hoseclamp method and had it off in a couple minutes - not sure why some people need an impact to get that bolt off?? Anyway.. I cleaned up the clutch surface on the pulley with some emery paper, and did the same to the supercharger side. I did pull one shim out, due to the wear on the clutch (80k on the car). My bearing was still good, so I didn't replace that.
Put everything back together and it's smooth as butter now - no chirp, just smooth unnoticeable engagement (except for getting thrown back in the seat ).
I think if you're just changing the bearing you'll be fine with the stock shim setup.
Old 05-06-2014 | 01:13 PM
Natibeastcat's Avatar
E90M3, E55 AMG
+1 shims??? getting ready to do this myself
Old 05-06-2014 | 01:21 PM
berti_00's Avatar
2016 Cls63s AMG
I have 3 in mine
Old 05-06-2014 | 03:14 PM
unagi1's Avatar
This will become all plainly obvious when I pull this thing apart...
Old 05-11-2014 | 06:46 AM
Basskrieg's Avatar
2003 C32 AMG
Torque on the bolt?
What was the torque spec you all used on the bolt after replacement?
BTW- my car has 145k miles, the bearing is squealing and is not wanting to come off, I modified a puller in hopes to get some grip on the pulley so I can remove it... will update with how that goes.
Old 05-11-2014 | 12:37 PM
unagi1's Avatar
I'm hearing 40 ft-lbs + red loctite from some of the other threads?
Old 05-11-2014 | 01:41 PM
kittyandgary's Avatar
2003 SL55 AMG
A comment was made above about getting rid of the supercharger 'chirp'.
I too had that on my SL55 when I bought it last summer. Over the winter, I installed the Belt Wrap Kit (from Shardul), along with the smaller SC pulley. Not a single incident of 'chirp' since they were installed. And, the acceleration rate results are very significant.
Old 05-11-2014 | 05:00 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Red loctite is the devil. Blue would be my preferred product to use.
Old 05-11-2014 | 10:07 PM
Basskrieg's Avatar
2003 C32 AMG
As far as torque on the 2003 AMG C32 SC pulley, it is NOT 40ft/lbs, it is 20nm (or 177 in/lbs, or 14.7 ft/lbs).
Old 05-11-2014 | 10:25 PM
Basskrieg's Avatar
2003 C32 AMG
My workaround for a stubborn SC pulley removal (with pics)
As luck would have it, the SC pulley on our C32 AMG did NOT want to come off. I had a hard time getting any gear pullers to grab onto the the pulley so while I was at the auto parts store I saw a cheap $6 puller that figured I would modify. You can see from the pics that basically I ground down the flanges so they fit the belt grooves of the pulley. I then tightened down a hose clamp around the puller flanges to keep it from slipping out of the groves and this worked like a champ. It allowed me to use this modified puller to easily remove the pulley. I then used the heat and freeze method to put the new bearing in the pulley and it worked like a champ! Thanks to everyone on these forums that always help with info!!! You all rock!
Attached Thumbnails S/C Pulley install Guidance regarding Shims-photo1.jpg   S/C Pulley install Guidance regarding Shims-photo2.jpg   S/C Pulley install Guidance regarding Shims-photo3.jpg   S/C Pulley install Guidance regarding Shims-photo4.jpg
Old 05-11-2014 | 10:32 PM
berti_00's Avatar
2016 Cls63s AMG
Glad you got it all working
Old 05-12-2014 | 04:17 PM
unagi1's Avatar
Confirmed that the actual torque spec for the center bolt on the e55 is 60Nm, or about 44 ft-lbs. Scan of BrianS's post attached.
File Type: pdf
Old 05-12-2014 | 08:49 PM
venomsE55's Avatar
E55 AMG
i had eurocharged do mine, i didnt see them put any shims in, i watch him pull the old one off and just put the new one on.
Old 05-12-2014 | 09:01 PM
berti_00's Avatar
2016 Cls63s AMG
The Shims are on there already you'd have to get of by hand gently without bending them. They left what was there and that's it. Some don't need more
Old 06-13-2014 | 11:04 PM
400RWHP's Avatar
2006 CL600
anyways
Steps..
easiest job ever
See those 2 pins sticking out of the shaft on the last photo? My car has never had those. Anyone else run into this? Do I need to worry about them? It seems to run like a raped ape so I'm wondering if they're necessary?
Regards
Old 06-14-2014 | 02:40 AM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
^^^ They've been sheared off when removing the bolt. I broke mine off when i removed my pulley for the first time. I just put the holes in the washer over the broken off bit and it still located a little bit and did it up with blue loctite... its been fine ever since.
People should be learning to use a feeler gauge when setting these up. They need to be between .35 and no higher than .55 or so imo. Once you start getting over .6mm I can see it putting stress on the springs that allow the thing to move. Thats how these things get fractured over time. With the shot bearing and the wear on mine it was at .8mm.... way to high.
Also for the high mileage guys that find there are big steps on the wear surface of the clutch surface i suggest you surface grind .1mm off it and then remove a shim or two from behind to get within the tolerance. My 230,000km car has never driven better since i did this and no chirp.
Old 06-17-2014 | 07:44 AM
Elhonaz's Avatar
W211 E55 2003
Hi guys! Doing this today, where exactly are the shimms located?
Old 06-17-2014 | 08:18 AM
viren.89's Avatar
2004 E55 AMG
Shims are right behind the pulley - you'd see them when you take it off. It's the circular metal things.
Btw there is a pulley failure thread in which the consensus was that "shims are on need only basis" that means- don't go by what someone posts here but
rather what's the stock distance between existing pulley. So if the existing distance is .35 maintain that and don't increase or decrease that.
Good luck
Quick Reply: S/C Pulley install Guidance regarding Shims
