another twin turbo e55 amg is born at BIP
Old 06-04-2014, 08:01 AM
  #176
chawkins2001's Avatar
2006 E55 AMG
Starting to make good power, up to 514rwhp at 12lbs on 93 pump. That's 10rwhp shy of my summer e85 numbers at 16lbs on my old setup.
We have run into our next snag, the car is dropping off in power fast at 6000rpms. The tranny stays in the gear we did the run in, and cuts out.
Old 06-04-2014, 10:25 AM
  #177
black06c230's Avatar
mgLipGD
Good job so far, I know you guys will get this latest snag taken care of soon.
Old 06-06-2014, 11:24 AM
  #178
2006 E55 AMG
Update is the car will not make power passed 5500rpms. It pulls good on the dyno and the street, but as it hits 5500 rpms, the power and tq plummet, badly. We have been working with a couple other tuners as well, and have come to the conclusion it is not in the tune.
I can honestly say, without this forum, I would not be this far in the build process. I have had a lot of help from others vendors. Jerry from Eurocharged has been a huge help. Although they are a online competitor, I will always give props when due.
Craig from staff@world motorsports on here, took time out his day and emailed me what he thought my fueling issue is. The email must have taken him at least 30-45 minutes to create. He wanted nothing in return, what a standup guy.
Last I have been talking to Steve @ Weistec. Super smart guy, and always there to answer my calls and trying to figure this thing out.
Paul Sullivan has also been a HUGE help. I don't care what anyone says, but Paul has helped me a ton, and not once said anything negative about his aborted build at IPS.
With all this wealth of information, I have come to the following conclusion, I need a different intake manifold as the NA version on my car does not work. It is not designed for forced induction.I say that because that cls55 TT that Jerry tuned and run a strong 10.96 on 93 at 4400lbs has a very similar setup to mine. Only difference is he has a custom intake and reused the stock intercooler. Well the tune used on my car, on Paul's car, and on the CLS TT is VERY VERY similar. Tony and Jerry verified that for me. We all know the CLS is done and was successful, Paul and I are having identical problems. I believe Elliott has the same NA intake, and I suspect he is going to run into the exact same problem. That intake causes way to much turbulence for forced induction, it simply cannot work.
In conclusion, and new intake has to be made, this issue is not in the tune.
Old 06-06-2014, 11:52 AM
  #179
Joncl's Avatar
E55
Chawkins sorry it hasn't worked out for you but I'm sure you will work hard for a new intake, I commend you for showing every step of the way what was happening. You and bip are honest guys. Good luck!
Old 06-06-2014, 12:00 PM
  #180
2006 E55 AMG
Thanks brotha, it is not easy, very costly, but will be worth it in the end.
Old 06-06-2014, 12:04 PM
  #181
berti_00's Avatar
2016 Cls63s AMG
thx for the updates Craig hope it all gets sorted out soon bro. So will it work if you guys used the same intake setup as the CLS did from powerhouse?
Old 06-06-2014, 12:10 PM
  #182
2006 E55 AMG
That's the route I am going, it is tried and proven.
Old 06-06-2014, 12:14 PM
  #183
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
while you are at it try to but a bigger IC brick since you will have some room to play with
Old 06-06-2014, 12:40 PM
  #184
whipplem104's Avatar
1990 300ce supercharged and intercooled
How are you dealing with the intake resonance flaps? Are they in short or long runner? You might try switch the position to see if it has any effect.
Old 06-06-2014, 12:44 PM
  #185
E55Greasemonkey's Avatar
Received 1,488 Likes on 986 Posts
This place is a joke.
Did you open up the intake manifold and remove all the flaps? I could see those getting forced close or other problems under boost.
Old 06-06-2014, 12:56 PM
  #186
I do not think you would want to remove them. You would end up with two intake runner lengths at the same time. I am pretty sure that would cause some weird air flow.
Old 06-06-2014, 01:05 PM
  #187
novae500's Avatar
W211
Stand up guy/shop to make the updated post to the board and give credit where it is due. I saw Paul yesterday at his shop and was telling me that you ran into the similar issues as he did.
  #188
2006 E55 AMG
Where are the flaps, I am not familiar with this at all?
Old 06-06-2014, 01:10 PM
  #189
RedBullJnky's Avatar
you to Hate
Inside.
We modified the intake 2 months ago, so we don't have that problem.
Old 06-06-2014, 01:13 PM
  #190
shardul's Avatar
Old 06-06-2014, 01:17 PM
  #191
rockthemullet's Avatar
2005 Mercedes E55 AMG
The M113 uses a variable intake runner design to add area under the power curve, much like subarus/svt focus/B-headed modular Fords/several v6 chrysler/MB cars. You can see them very well here (post 2, picture 6):
https://mbworld.org/forums/s-class-w...d-r-r-diy.html
Subaru guys often delete them as they're electronically controlled and sometimes fail
Old 06-06-2014, 01:18 PM
  #192
Originally Posted by RedBullJnky
Inside.
Oh nice! Might be an easier solution that you guys thought
Originally Posted by shardul
Beat me
Old 06-06-2014, 01:53 PM
  #193
2006 E55 AMG
you guys rock, I will pull the intake off and check mine.
Old 06-06-2014, 03:15 PM
  #194
Sorry I wasn’t clear; I was thinking more along the lines of removing the flaps, or fixing the others in place depending on which runners you'd want,or just grinding and gutting the. inside to make it an open plenum. Don't know anything about Turbo builds and what works best.
Old 06-06-2014, 04:00 PM
  #195
TTE55's Avatar
05 E55 AMG, 2011 Range Rover Sport SC, 2004 BMW 745Li
You can definitely remove the flaps, the upper or both sets of runners inside. It is worth a shot to see if the car improves on the dyno. It would be the cheapest fix. The reason we decided against removing them was that once they were removed you basically have no runner, which can affect the torque. The second reason was that the air didn't have a straight path without the runners in. And lastly because with the large open void of having no runners you can actually create turbulence as the turbos are pushing air in. Obviously I dont have the "proven" numbers yet. But after some flow testing of the NA intake manifold thats why I decided to go with a different intake. Hope to see your car running strong soon Craig!
Old 06-07-2014, 06:31 PM
  #196
groove66's Avatar
2005 e55
I would stick the flaps in the short runner position versus the long runner position. Also run a one check valve to the flap acutuators so they don't see boost
Old 06-07-2014, 08:21 PM
  #197
you to Hate
Have Jason text me Monday.
Old 06-07-2014, 11:17 PM
  #198
2319's Avatar
2005 E55
Craig,
Which port are you using on the wastegate? This is why you are only seeing 12 lbs.
Old 06-08-2014, 10:21 AM
  #199
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
I am not familiar with the Mercedes setup, but if the flaps are vacuum activated, if it is possible to switch the runners by adding check valve, vacuum can, solenoid and RPM switch, you would see better performance across the board. Long runners help low end 0-to ~4000 RPM (which helps area under the curve during acceleration), short runners help the top end. Since we are automatics we'd stay in the upper band more often.
If you are only concerned with peak horsepower, use only the short runners.
How are they currently setup? Is vacuum applied at all? Try applying constant vacuum during a pull before pulling IM.
Old 06-08-2014, 06:16 PM
  #200
2006 E55 AMG
Will do brotha
Quick Reply: another twin turbo e55 amg is born at BIP
