Does this happen to you ?
Old May 23, 2014 | 11:59 PM
E55amgsd's Avatar
05 e55 amg
Ok so before I get the" search first then ask " answer .. I did search ..lol Ok so I'm worried that I might get locked outside my own car ..key sometimes works perfectly and sometime I'm stuck there pressing the buttons till it finally opens ..I have to give lil hits..could this be the battery?I read that when battery is low the car will tell you when u put the key in the ignition ?true ?
Old May 24, 2014 | 12:11 AM
Enigma94's Avatar
C32, C55, 08 E63
It could be the battery or the IR sensor in the remote or the door. Chances are it's the battery since the remote still turns the car on I would eliminate the remote IR sensor so your best bet would be to change the battery then check the door sensor.
Old May 24, 2014 | 12:12 AM
MAN55LE's Avatar
04 E55 AMG
When I bend my key and press the button it works .....sometimes if I just press it regularly I get the same symptoms of you, but I've been lazy and haven't even replaced my key fob battery I bought my car in March of last year. ..... Basically I hold one finger at the tip of the key and one finger at the base of the key and when I press the button it bends the key fob and presses the button at the same time ....and it generally works always when doing that!
Old May 24, 2014 | 12:42 AM
E55amgsd's Avatar
05 e55 amg
Thanks bro ..but I think the door sensor is good what o do sometimes I put the key on the door handle and press the button and it opens ..so it must be the battery ..thanks
Old May 24, 2014 | 12:46 AM
E55amgsd's Avatar
05 e55 amg
Seems like your your way around it hu lol ..I'll try that.. but first thing tomorrow I'll replace the battery ..it's embarrassing sometimes .."oh amg guy ,fancy car and can't open his door "haha :/ what people might say bout me ..so I act like '---ohh look I have a dirty spot on the door ---and while I'm pressing the buttons I pretend I'm cleaning the dirty spot hahaha had to share ..thanks bro
Old May 24, 2014 | 12:56 AM
MAN55LE's Avatar
04 E55 AMG
Fawk what people think!....but I hear ya.
Old May 24, 2014 | 01:07 AM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
Remote battery. Battery is a 2032. Available just about anywhere that sells batteries. Takes about 30 seconds to replace it.
Old May 24, 2014 | 01:15 AM
MAN55LE's Avatar
04 E55 AMG
Talk about lazy ...I shoulda changed earlier Thank You
Old May 24, 2014 | 01:21 AM
marcmaddox's Avatar
Yeah. I change mine about ever 6 months just as a routine maintenance item. It's possible your remote is defective. If it's got green sludge buildup or it's obvious that a solder joint is fractured on one of the contacts a new one may be in order. You will notice any thing obvious when you pull the guts out of the case to change the battery.
Old May 24, 2014 | 06:56 AM
E55amgsd's Avatar
05 e55 amg
Hahaha yeah fawk em ..thanks
Old May 24, 2014 | 07:00 AM
E55amgsd's Avatar
05 e55 amg
Thank you for the info do i have to reprogram anything on the key ?..you know ..or is it just fine after removing batt ?and would it work fine after the removal
Old May 24, 2014 | 07:59 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Key signal antenna amplifiers are know to go bad. It is a green box located on the driver side B pillar
Old May 24, 2014 | 09:06 AM
E55amgsd's Avatar
05 e55 amg
Thanks ill replace that to .
Old May 24, 2014 | 10:18 AM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
You do know about the key blade in the remote too right? If your remote battery is completly dead the blade will unlock the doors. The remote key will still start the car if its battery is dead. Key batteries can last 6 monts to 3 years depending on use and believe it or not storage temperature. Once a year is recommended by MB.
Old May 24, 2014 | 04:59 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Same thing here so I changed my batteries.
Old May 25, 2014 | 04:14 PM
Worth the wait's Avatar
2006 E55
Mine tells me when my batteries need changed.
Old May 25, 2014 | 04:36 PM
E55amgsd's Avatar
05 e55 amg
Yeah I seen the blade...is there any link on how to change battery ? Thanks
Old May 25, 2014 | 06:08 PM
E55amgsd's Avatar
05 e55 amg
Did some searching on YouTube(found a video ) and finally changed my battery now my led red light flashes every time I press the buttons )
