what would cause one side of the rear to be lower than the other?
2005 E55 AMG
my son swears the driver side is about an inch lower than the passenger side in the rear, I'm starting to think the same thing - what's the best point to measure from - the center of the wheel hub? or from the ground?
what the heck would cause this?
How much lower is it? Are you sure the car is on a leveled area? Best way to measure is from the fender all the way to the ground... just make sure the measuring tape is straight.
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
measure from the fender through the center of the wheel to the ground... you can see if tire is sitting low or its the shock.
I do believe it is somewhat common though for the rear to be off a bit. There is only 1 sensor on the airmatic in the back
2016 Cls63s AMG
mine was like that... i did raise and low kind of method i found online somewhere and it leveled fine. find a flat nice surface ( i did mine in a nice flat parking lot at the beach on some high end condos so it was flat) drive full car length raise it while leaving the door open (dont ask me why, i read it somewhere) do it like 5 times in a row up and down up and down. Supposedly it re levels the car from doing all the roll and stops raises and drops
haaa... i saw this exact scenario on mine 2 days ago and figured it was a rear airmatic going bad. I literally just logged on to ask this exact question...awesome forum..
2005 E55 AMG
totally spaced on posting this, I still have to measure it, could be my driveway, but I can report back later
