fighting dreaded steering wheel wobble/shimmy
when i first re installed the wheels everything was fine, the more i started to drive the car 45mph to 70 mph the car would start to shimmy at the steering wheel again.
the shimmy/wobble is not all the time but is pretty frequent.
i already replaced driver lower ball joint due to sqeaking over bumps at low speeds and wheel bearing due to humming.
i have 5mm spacers up front that i will remove and see if it helps and plan on doing an alignment once i get this figured out.
thoughts on whats causing this?
update:
got the car on the lift, and noticed a little movement at the 12 and 6 position. 9 and 3 seems tight on both wheels
Do you see the passenger seat move due to the vibration?
i loosened the 5mm allen on the lock nut on the hub and was able to tighten the locknut a 1/8" by hand so i removed the bearing repacked it, re tightened and re assembled everything. as of now the wheel is tight in all directions. when i get out of work and go for a drive ill know for sure.
i literally just found my dial indicator with magnetic base after i re installed wheel, if issue re arrises i will do it with the indicator.
This fixed my issue a few times
could a sticky caliper be causing this? i noticed when i spin the rotor by hand there is spot that catches . but when i reinstalled the wheels and spun them in the air they seemed to spinning on there own with 0 issues.
i measured them on my granite table and tesla height guage, saw as much as .0090" of a difference between beetween the lug holes height.
going to try to order another billet set in 10mm with a hubcentric ring.
i actually started to lap these spacers on a granite plate with sand paper and the drivers one has all sorts of high and low spots.
