Burning Oil on Exhaust Manifold
i mean the engine, near cylinder 8 and managed to get oil on my fingers. What are you thoughts guys? Valve cover gasket? Head gasket? Ill get a proper look when daylight strikes tomorrow but i need your thoughts on where to look first.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
If you already have the MAP sensor, you might as well change it out... you're already there
Thank you all for your help
In this pic, the grommet was actually pulled out, but it is resting right on top of what it should be sticking in to.
Hope that helps! If you don't get it right, you will get a CEL and a high idle by 2-300 rpm.
