Time to paint the intercooler heat exchanger black!
Really surprised how big a difference black paint could make!
Now, if we all ran our cars with a hairdryer on a workbench, then we are talking!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
But with that said, now you know why engine radiators are commonly black from the factory :-)
https://en.wikipedia.org/wiki/File:F...ing_engine.jpg
https://en.wikipedia.org/wiki/Formul...W12_Engine.jpg
I had a debate going with a buddy about this and I told him the test was far from real world as IAT's at idle are going to be barely above ambient as there is nearly no compressed/heated air going through the cooler. Not to mention an intercooler or HE sitting on a table isnt the same as on a running car in front of a hot radiator and engine.
Bottom line is if you want to paint it black..fire away but it isnt going to make it better or worse.
