Preliminary Snow Experience
Old Dec 8, 2003 | 10:54 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
Cool Preliminary Snow Experience
Well the snow was significant here in the NYC area. My drive home Fri afternoon with the stock Conti's was significantly better than expected. Did not get stuck, lost traction slightly but still able to maintain control between the manhattan leg and the bronx leg of the triborough bridge.
Sat am put on my snows - 18 x 8 all around Dunlop M3's. No problem on semi-cleared roads. There was a bank parking lot unplowed Sun AM - this had a fair grade and I had no problem. Obviously I did not push it, but the car handled fine with no traction loss.
How about others experiences ?
Old Dec 8, 2003 | 11:17 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
sorry no snow duty for my 02 E55. Eddie, what wheel are you using with your snow setup? Thanks.
Old Dec 8, 2003 | 11:21 AM
BoBcanada's Avatar
AMG
Re: Preliminary Snow Experience
What e55 you have? w210 or w211?
Old Dec 8, 2003 | 11:27 AM
It's a W211 E55. I'm using the 18 " AMG double spoke (identical to the front stock wheels). The knock-off wheels that Tirerack had really looked bad - so what the he**.
Old Dec 8, 2003 | 12:15 PM
E55 KEV's Avatar
Veteran: Air Force
What' knock off wheel?
That was probably before Tire Rack had the real W211 E55 AMG in stock. When you search under the E55 Winter section they now show the OEM front wheel for $449.
Old Dec 8, 2003 | 12:46 PM
That's the set-up I got. I must say - it looks good as well.
Old Dec 8, 2003 | 02:27 PM
BoBcanada's Avatar
AMG
So you are saying it is possible drive it in a snow with winter tyres right? Because for me it's the biggest concern! Did you drive in C mode? That's good news tho! Loking forward of getting one by feb/march...
Old Dec 8, 2003 | 02:41 PM
Yes, I had no problem - in "C" mode. Obviously you have to take it easy though
Old Dec 8, 2003 | 04:01 PM
Pbglas's Avatar
E55
Thanks Eddie Knopp. I have been thinking of going for something else than E55 because of snow. Are you saying you managed with the stock high performance tires? Wow. If I remmeber corectly, you would have to go up and down some mild inclines.
Old Dec 8, 2003 | 04:56 PM
ajoe's Avatar
Had no problems with Dunlop M2's
Mounted on OEM wheels they worked well on hard packed snow and ice as well as several inches. Of course stupidity can overcome any good product as many awd drivers found out this past weekend.
Old Dec 8, 2003 | 05:55 PM
cb44's Avatar
The E55 is no different from any other RW drive sports sedan when it comes to snow or ice....they are not very good in many situations. In fact I would suspect that the E55 with it's additional torque is very unhappy on slippery ground.
Winter traction is more an issue of tire than of the car wearing them. Sport tires generally are designed for dry tractable surfaces and snow and summeer tires do not a happy couple make.
Old Dec 8, 2003 | 09:06 PM
Yes I did manage on the stock Conti's, but that's just it - managed - the next AM I had my snows put on. They handle well in the snow, but not with the same traction on dry asphalt.
Spring will be back soon (I hope).
