Quick questions on 3 mods.. cooling/belt wrap/front lip
Old Jun 18, 2014 | 09:35 PM
fergsc32's Avatar
2011 c63 AMG
I am at my 2 month anniversary with the e55. having a blast still. Aside from general refresh of maintiance items, ive not done an actual mod yet. I do have a crank pulley and tune and the johnson IC pump from eurocharged.. but these came on the car when I bought it. I have 3 questions
1: ..is the belt wrap kit a worthwhile mod..Ive seen these from 375-500 from various vendors.. any differences in these units?
2: is there a preferred unit for the upgraded heat exchanger..one thats direct fit without altering the bumper and such
2: i like to look of the front carbon lip.. are they all pretty much the same or is one vs another preferred those who have it?
many thanks on the input
Old Jun 18, 2014 | 09:38 PM
Hulk's Avatar
A Merc
Belt wrap, ask shardul
Heat exchanger the plm is a good one and doesn't alter the bumper
On the cf lip Gary suvneer
Old Jun 18, 2014 | 09:45 PM
fergsc32's Avatar
2011 c63 AMG
ya i just came across the plm.. 355 shipped.. cant beat it !
Old Jun 18, 2014 | 09:52 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
1. Yes
2a. Make sure the H/E you purchase has mounts for the cooler located underneath the factory H/E
2b. Suvneer here as well
Old Jun 18, 2014 | 10:18 PM
fergsc32's Avatar
2011 c63 AMG
Originally Posted by HeissRod
1. Yes
cool thanks !
Old Jun 18, 2014 | 10:32 PM
bierry's Avatar
E55
My performance shop who has worked on MANY E55s actually advised me against aftermarket HEs, saying they're a waste of money since there's no increase in frontal area and would not speed recovery. Any truth to this?
bierry's Avatar
E55
a
Old Jun 19, 2014 | 02:03 AM
HeissRod's Avatar
Old Jun 19, 2014 | 03:00 AM
ss.dna02's Avatar
05 E55 AMG
Just installed the PLM H/E and it fit perfect and it has mounts for the bottom cooler.
It also does not push the bumper down.
Old Jun 19, 2014 | 03:08 AM
OZZYAMG's Avatar
03 W211 E55
Hi
Does anyone have a picture of what happens when you install a front cooler that pushed the bumper down?
Regards,
OZZYAMG
Old Jun 19, 2014 | 11:50 AM
fergsc32's Avatar
2011 c63 AMG
sweet.. thanks for the input...do you have to remove the entire bumper??
Old Jun 19, 2014 | 12:33 PM
HeissRod's Avatar
Yes
Old Jun 19, 2014 | 06:34 PM
AllCounty E55's Avatar
2003 e55 AMG
Correct me if I am wrong...according to a bunch of research I have done and speaking with different sources ( kleemann & renntech ) the HE doesn't actually make the car run cooler but run cooler more consistently if your hot lapping or track racing....correct?
Old Jun 19, 2014 | 07:38 PM
Celicasaur's Avatar
W212 - E63 AMG
Yeah helps the recovery time, but I suspect would be particularly helpful in a hot climate and if you drive in lots of traffic then would suddenly like to go full throttle to 100mph a few times in a row.
If on a budget and you're not expecting to repeatedly hold the engine at full throttle several blasts at a time, you might be able to get away without doing this mod.
lol that being said, I will get one for my car soon. A cooler running engine is less likely so knock than a hotter one (ie, super hot intake temps = not ideal), which incidentally is why nitrous is such a good power adder for an engine if/when installed and used properly.
Old Jun 19, 2014 | 08:29 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Not true.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 19, 2014 | 09:05 PM
SilverStrk's Avatar
05 E55, 07 ML500
Originally Posted by Exotic-metal55
Not true.
THIS.../\/\/\/\/\... Do your research.. Good luck...
