Question On Secondary Cats Delete....
Alright, so I deleted the secondary cats and resonator about a year ago and I'm selling my vehicle as a trade through a buy bid at my dealership and the stupid CEL has thrown an O2 code on the right side since the delete.... So I tried getting defoulers to essentially trick the ECU but that's not working too well. My question is, where the hell can I get the most inexpensive cats to put back on and just be done with the damn thing?
My biggest mistake was to not keep them....
That's what I've been told before but it started within about 2 days of the delete and when I reset it it stays off for about 2-3 days then comes back on... I just figured it was the delete. Could they literally just be bad O2 sensors?
The code will tell you which sensor it is, being up or down stream and which bank, being driver or passenger. It is merely coincidence that you had a O2 fail shortly after the cat delete. If you have a code the worst thing you can do is ignore it by deleting it. The problem is still present hence why the PCM notified you of the issue. Let me know what codes are in the PCM and I can help you with which sensor(s) it is.
