I/C Pump connection
Old Jul 3, 2014 | 09:05 AM
T9ja's Avatar
2005 E55 amg
I/C Pump connection
Can someone please explain which hose goes where. Need to know if both openings on the i/c pump are suppose to be connected directly to the H/E, using the hose or if anyone have a diagram to show the connection. Thanks.
Old Jul 3, 2014 | 09:40 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
bottom to inlet of pump top to outlet of pump
Old Jul 3, 2014 | 09:43 AM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Hose from heat exchanger > inlet of pump. Hose to Supercharger/IC connects to pump outlet.
Old Jul 3, 2014 | 10:35 AM
T9ja's Avatar
2005 E55 amg
Thanks for the response guys. Are both of those hose coming out from both of the H/E holes, and both going into the pump or not? Need to know if it's the bottom hole or top hole of the H/E that goes into the pump inlet or vise versa.
Old Jul 3, 2014 | 10:43 AM
shardul's Avatar
bottom goes to inlet of pump
Old Jul 3, 2014 | 07:47 PM
RAWE55's Avatar
C63 AMG, E55 AMG
Only 1 line from the heat exchanger goes into the pump (The bottom one) its short enough that it cant go anywhere else. The other line on your heat exchanger (the top one) is coming from your intercooler, this is the hot fluid that has passed through the intercooler and is injected at the top of your heat exchanger to be cooled before being pumped back up the line.
Old Jul 3, 2014 | 08:42 PM
Bramage's Avatar
F-250
I have all the information you need. However, like every other *** on here, I wont tell you Neener Neener.
Old Jul 3, 2014 | 10:21 PM
T9ja's Avatar
2005 E55 amg
Thanks! That's more informative.
Old Jul 4, 2014 | 12:08 PM
Bramage's Avatar
F-250
Old Jul 4, 2014 | 03:20 PM
T9ja's Avatar
2005 E55 amg
Bramage; thanks. It made it much easier to trace. I've been feeding on hot fluid. Just traced each connections and found out, the top hole of the H/E is connected directly into the pump inlet, and the bottom hole is going to the intercooler. First thing on Monday morning, I will pay the mechanic a visit. Thanks every one for your information.
Old Jul 4, 2014 | 03:32 PM
Bramage's Avatar
F-250
Change pump while you are in there (If you haven't already)
Old Jul 7, 2014 | 01:38 AM
Elhonaz's Avatar
W211 E55 2003
Originally Posted by Bramage
Great pic indeed! So the HE is the "110/11" part, where air cools the fluid down? And intercooler is under SC, and there water cools the intake air?
