82mm throttle body without adapter plate
Old Jul 4, 2014 | 10:03 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Here's a few pics of a cleaner (IMO) way to install a larger throttle body. The adapter plates work great also, but this way gives up no clearance for a larger intake tube to the firewall like a plate will. You could also slice the inlet with a band saw and weld the adapter plate on if you already have it, but I'm just posting this to show another way. The aluminum I formed to the top was 7mmX16mmx120mm for those interested.
82mm throttle body without adapter plate-0f463035-d968-45f1-8e68-6d04454350e0_zpsmctgivko.jpg
Sorry I got rolling and forgot to take pics of the port work and sanding. I dusted some primer on it, a little aluminum cast grey paint will have it looking almost factory once installed. Also I tapped and Heli-coiled some M6x10 steel threads into it so the bolts don't strip out.
82mm throttle body without adapter plate-9b7bf362-89ad-4d3a-93b7-83582200a24a_zpsibdi9mtr.jpg
82mm throttle body without adapter plate-f35a05b7-6b38-47f4-97dc-3ef62436fe55_zpseqbsho2a.jpg
82mm throttle body without adapter plate-36aa31cb-9dad-4466-8cc0-dbc65cda0ad7_zpsbhaqcvyi.jpg
Old Jul 4, 2014 | 10:08 AM
marcmaddox's Avatar
2005 E55 AMG, 2012 GL550, 2000 Ford Lightning, 2005 Chevy Silverado 2500HD
Nice!
Old Jul 4, 2014 | 11:18 AM
E55Greasemonkey's Avatar
This place is a joke.
I see you had your nails done as well.
Old Jul 4, 2014 | 11:32 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Perfection
Old Jul 4, 2014 | 12:17 PM
kompressede's Avatar
Sold - 05' E55
Very Nice -
Old Jul 4, 2014 | 12:21 PM
Denroll's Avatar
'06 E55
That's nice. I'd like to pick up a spare inlet and do this for my 90mm.
Old Jul 4, 2014 | 01:22 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Old Jul 5, 2014 | 05:15 PM
BC928's Avatar
2006 E55, Various other German and ‘Murican
Looks good.
Old Jul 5, 2014 | 06:21 PM
Duc1098E500's Avatar
Honda Metropolitan
My wife said the same about his nails. Lol
Old Jul 5, 2014 | 06:26 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Well done sir.
Old Jul 5, 2014 | 09:21 PM
BC928's Avatar
Private messages are full, sir-boost.
Old Jul 5, 2014 | 09:43 PM
RedBullJnky's Avatar
you to Hate
I sent you a pm also
Old Jul 5, 2014 | 11:09 PM
HeissRod's Avatar
I don't know anything about working with metal. How did you.....weld it on?
Old Jul 6, 2014 | 08:43 AM
e55amgrocket's Avatar
Dirt Scooters
That's similar to how I did mine. I just had a friend weld on more material then drilled and tapped for the bolt holes and opened the hole up to 85mm
Old Jul 6, 2014 | 10:08 AM
Bramage's Avatar
F-250
Same.. My snout was "Added to" Then re-tapped by my buddy Bruce at TTM.
I never had the dreaded "Hiccup" and always wondered if it had anything to do with people running adapter plates. We know if it leak its an issue.
Other thing: You can better match bore the TB Denroll, you would probably pick up 5 HP just with that mod. You can get the snout from dealer, but if I remember, its around $280 (Get the 80mm Snout). I cant remember the model.. S55 maybe
Old Jul 6, 2014 | 12:13 PM
Denroll's Avatar
'06 E55
I want to get another one and try it out. Mainly, I want the extra room from ditching the spacer so I can fit an actual Y-pipe.
Old Jul 6, 2014 | 12:41 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Intake
Intake,prototype
Old Jul 6, 2014 | 12:50 PM
Denroll's Avatar
'06 E55
I may have just jizzed a little. Can you provide me info on that setup?
Old Jul 6, 2014 | 01:45 PM
cnterline's Avatar
It's on an SL won't fit your car ,at least the intake set up I made wont you'd have to cut into your firewall ,there's a plate on SL you can remove and it's still a has sell.im still fine tuning it ,lost of clearance issues there is a guy selling his SL (55 with same set up but a different intake that might work for you
Old Jul 6, 2014 | 01:51 PM
cnterline's Avatar
Sl55
Intake on sl55 for sale
Old Jul 6, 2014 | 01:53 PM
Hulk's Avatar
A Merc
No that intake was custom made for the SL
Old Jul 6, 2014 | 01:56 PM
Joncl's Avatar
E55
That looks like very clean work!
Old Jul 6, 2014 | 03:39 PM
Denroll's Avatar
'06 E55
Man, what a weewee-tease.
Check out how the TB is mated to the inlet in the second pic. Interesting.
The E engine bay is just so tight back there. I can *barely* fit the stock Y-pipe as it is. I've considered notching it out.
Old Jul 6, 2014 | 04:13 PM
Hulk's Avatar
A Merc
All custom work , hard to do but the best way
Old Jul 6, 2014 | 05:01 PM
BRH AMG's Avatar
E55 AMG
82 mm throttle body
I did mine in a similar way, machining, welding and shot peening. I found filling the voids inside increases the flow coefficient as much as 15%. More of a venturi.
