Water Pump Possible Future Replacement
Old Jul 9, 2014 | 09:35 AM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
I live in a very hot environment and drive a vehicle where the motor runs very hot at times so am wondering aside from all standard cooling mods shown in my sig should I keep a spare water pump on hand just in case?
Old Jul 9, 2014 | 10:23 AM
MindBend's Avatar
'05 E55
If you are overheating, check fan operation and thermostat. Also, consider less coolant and more distilled water and Water Wetter.
Also, be sure radiator isn't clogged and ductwork is intact, forcing air through it, not around it.
Good luck.
Old Jul 9, 2014 | 10:34 AM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
Originally Posted by MindBend
If you are overheating, check fan operation and thermostat. Also, consider less coolant and more distiller water and Water Wetter.
Good luck.
^-------------Plus one!
Old Jul 9, 2014 | 10:35 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you can run a PTE 170F Tstat
Old Jul 10, 2014 | 03:01 AM
I was only asking as a precautionary measure as a friend has indicated it might be a good idea considering the heat where I live. The temperatures here get up to around 120 degrees in summer.
