looped fuel rail & return
Old Jul 27, 2014 | 03:27 PM
cij911's Avatar
one car at a time
Is anyone (other than Craig) running a looped fuel rail with a return line ? I am wondering if it would be beneficial to do this as well as an aftermarket FPR, fuel pumps, and external filters. Thanks in advance
Old Jul 27, 2014 | 10:18 PM
chawkins2001's Avatar
2006 E55 AMG
Let me know if you need pics and parts list brotha. Its not hard to do and fairly cheap.
Old Jul 27, 2014 | 10:31 PM
SICAMG's Avatar
2005 e55 AMG
I do I do!!! A parts list and pics would be great. Thanks
Old Jul 28, 2014 | 12:11 AM
jcjmw's Avatar
2005 E55 Wagon
Me!!!
Or, better if you put together a kit with instructions!
Old Jul 28, 2014 | 07:11 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I'm into this also! I'm past the service interval, and don't like the idea of buying parts known to fail on a regular basis.
Old Jul 28, 2014 | 08:09 AM
MindBend's Avatar
'05 E55
Interesting. How/where does the fuel return to the tank? I agree that getting rid of that mess is a good thing. (so long as Frankensteinian surgery isn't required!)
Old Jul 29, 2014 | 09:19 AM
jmb614's Avatar
E55 AMG
You already know I'm in for pics and take-off
Old Jul 31, 2014 | 08:07 AM
2006 E55 AMG
return line, removed factory fpr, -6an feed and return off looped portion, 2 inline filters:
Attached Thumbnails looped fuel rail & return-img_3598.jpg   looped fuel rail & return-img_3582.jpg   looped fuel rail & return-img_3581.jpg   looped fuel rail & return-img_3577.jpg
Old Jul 31, 2014 | 08:12 AM
2006 E55 AMG
more pics
Old Jul 31, 2014 | 08:17 AM
jmb614's Avatar
E55 AMG
Thanks for the pics! Do you recall if there is a Y or T anywhere in the stock feed line going from the back to the front?
Old Jul 31, 2014 | 08:36 AM
Roverron's Avatar
ML63
Will this need the ECU recoded so that it doesn't throw a code?
Old Jul 31, 2014 | 08:37 AM
Nice setup. I was hoping to also eliminate the factory pump. I guess it's good enough.
Old Jul 31, 2014 | 09:16 AM
BRABUSCL600's Avatar
Escalade ESV Platinum (Blue Chip), 2004 E55 (SOLD) , 2001 Brabus CL600 (SOLD), 1997 E420 (SOLD)
If you put together a kit, I'd buy it!
Old Aug 1, 2014 | 01:14 PM
jmb614's Avatar
E55 AMG
+1
Old Aug 1, 2014 | 01:39 PM
Denroll's Avatar
'06 E55
Nice stuff. What was the approximate cost of parts?
Pics need more instagram filters. I can still make out some of the colors :P
Old Aug 1, 2014 | 04:44 PM
Bramage's Avatar
F-250
A kit would be a hot seller and especially if it had a pump replacement option. Our OEM pumps are stupid expense. I imagine a much better solution could be developed (in kit form) that was close to or cheaper than the $1000+ needed to replace oem..
Old Aug 1, 2014 | 06:02 PM
I'd gladly spend the thousand to avoid oem in this case
Old Aug 1, 2014 | 06:33 PM
2006 E55 AMG
I promise to get a kit together for the fellas. I have had a lot of PMS, just been busy trying to get my sled finished.
I will have a kit priced by the end of next week and could drive cost down even more if a group buy was started
Old Aug 1, 2014 | 07:39 PM
RedBullJnky's Avatar
you to Hate
Old Aug 2, 2014 | 03:25 AM
OZZYAMG's Avatar
03 W211 E55
Hi
Would the supercharger need to be removed to fit this kit? I only have a standard fuel rail at the moment.
Regards,
OZZYAMG
Old Aug 2, 2014 | 09:07 AM
cij911's Avatar
one car at a time
Originally Posted by OZZYAMG
Hi
Regards,
OZZYAMG
One can install a looped fuel rail with the supercharger still on the engine, so I would guess the same for the kit install.
Also, Craig is NOT using the OEM pumps. He had a thread about replacing the pumps with dual 340lph aeromotive pumps.
Old Aug 2, 2014 | 09:15 AM
Roverron's Avatar
ML63
If you have a return line why would you need to loop rail?
Old Aug 2, 2014 | 09:20 AM
cij911's Avatar
one car at a time
Isn't a setup with a return line technically a looped rail ? I guess it just depends on where the line in and line out are located...
Old Aug 2, 2014 | 11:20 AM
cm60k's Avatar
As i know; reason of looped rail, for eliminate possibility of starvation in the end of the rail (cylinder #8), during WOT or high rev situations...!
not sure why MB looped the rail for (4.2/5.0 M119 & SLR M155) only..!!!!
ZAYED,,
Old Aug 2, 2014 | 11:33 AM
Hulk's Avatar
A Merc
For the SLR it was because it has higher stock boost , that's why when adding boost to these engines smart move is to install a looped rail and bigger injectors
