Wideband guys???
Wideband guys???
Ordered a dual wideband set up with control box. Where is best place to run cables through firewall? Where do most install box? Thanks for any help.
Nevermind wrong question
There's a grommet in the passenger footwell when you remove the foam and rest plate. To the left, above the 1/0 gauge coming from the battery in the trunk
I used the power and ground off of the back of the cigarette lighter. This is a convenience item, the wideband won't power on if your battery is too low.
You can get switched power in fuse panel, tap into Cigarette lighter, or use cigarette lighter to trigger relay (which is what I did)
But I am running a lot of junk off of direct feeds from the battery, so the switched power to relay works well. Used this for Intercooler pump too
here is where you get power in fuse block: (Disregard second part of picture, that's just for sensor taps)
So how do you get to the wiring for the lighter without taking the dash apart?
Thank you, will try that out today
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
I read those wideband kits can emulate a narrowband signal via their control boxes, right?
Anyone uses this? Does this work with the 55's ? Where to connect what?
Anything else recommend than Zeitronix?
My OT-2 seems to have taken a crap (ughh)....Hopefully Innovate will replace it, otherwise I will be looking at the ZT-2 (which I have loved for turbo'd cars).
I just picked up the PLX kit, DM-6 SM-AFR Gen 4 Combo along with the Kiwi BT and IMFD cable. Very easy to hook up and I will give more info as I use it in the next few weeks
I have it setup as such....Kiwi2 BT hooked up to the SM-AFR to the sensor. The idea was to get the signal from the AFR to the Kiwi so I can read all that info via bluetooth. Also live AFR readings from the DM gauge and log with either ScanXL or DashCommand
