Standalone and functionality.
Old Oct 17, 2014 | 08:26 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Originally Posted by Mitch Detailed
Haltech elite was released today. Its obd2 compliant, and ill be picking one up to gradually phase out the oem ecu. First fuel, then ignition, then throttle and can configuration..
Once I complete the task ill offer kits for wiring and write ups on terminal pinouts.
Keep us posted, maybe start a new thread once you get the product.
Old Oct 17, 2014 | 08:34 PM
Mitch Detailed's Avatar
2006 E55 AMG Kompressor
Will do. Ill be running a haltech emulator 8, along with their elite ecu. The emulator gets the required outputs to look right, while required inputs will be ran in parallel. Nonetheless. Ill be the standing proof it can be done
Old Oct 17, 2014 | 08:36 PM
Hulk's Avatar
A Merc
Hope it works , it would be awesome to have
Good luck
Old Oct 18, 2014 | 11:41 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
I just took a look at this ecu and the CAN is not configurable. There are just preselected vehicles that they have done. And it clearly states that other systems do not work such as traction control. Have you spoken with Haltech about working with you on the CAN messaging?
The only fully configurable ecu that I know of is the Motec M1 with the Build package. Huge money and you are righting the entire firmware package for the ecu. Very complicated and large amounts of money.
Old Oct 18, 2014 | 11:54 AM
Where did you find this traction control not available ? There's 4 inputs for hall effect sensors on the unit. Considering that we only have a cam, crank, and vss, we're only missing 1 front wheel speed sensor signal from the basis of controlling traction..
Fwss/vss = f(x), if f(x) sways +-10%, retard timing.
I say +-10%, but its really one way it needs to go, the value offering if the front wheels spinning faster isn't gonna happen.
Old Oct 18, 2014 | 11:57 AM
Ive got some resources that ill be using to gather information for what haltech needs to know in order to get can communications with the car. As of right now, im more focused on getting fuel control, and ignition control in a piggyback fashion and addressing those issues accordingly.
Old Oct 18, 2014 | 12:21 PM
  #32
I meant the factory systems.
If you are going to work with the CAN bus you do not need to wire up any wheel speed sensors. Just pull the data from the bus. Also you may find that reading the factory sensors on newer cars is not possible. They use a very distinct output voltage that is very low and but mostly there is a very high number of teeth or pulses per revolution. This pushes the frequency range over what most computers can read a relatively low speeds. I do not remember if the w211 still has a standard magnetic sensor on it or the newer 2 wire digital sensors.
Old Oct 18, 2014 | 12:23 PM
  #33
Also, I am not trying to burst your bubble just pointing out things to look out for. Knowing what you are up against is always good. I have been looking at the M1 build for doing something similar.
Old Oct 18, 2014 | 01:08 PM
  #34
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Originally Posted by cij911
Whipple - Would it not be easier (& cheaper) to go more of an openecu route and use the factory ECU, but be able to trace and flash (tune) without a crazy expensive and proprietary interface ? You seem to have more than enough knowledge to know whether this would be possible with our platform. (TIA)
That would be a great route if we could get some of the guys that worked on the EVO ecus on the case. There is a lot of talent out there that made what was supposedly impossible without standalone possible.
Old Oct 18, 2014 | 01:11 PM
  #35
WANTED!!'s Avatar
Sweet!! This should solve a lot of the issues people have been having, especially in the turbo conversions.
Old Apr 12, 2025 | 04:24 PM
  #36
Bab26's Avatar
E55 w202 2.3 turbo
Has anyone figured it yet
Has anyone figured this yet ?? thanks
