Denroll's 90mm TB inlet
Old Sep 4, 2014 | 09:38 AM
  #51
rockthemullet's Avatar
2005 Mercedes E55 AMG
Originally Posted by Denroll
Like any good sophisticated redneck, I am well stocked on JB Weld.
Clearancing the surge tank would be the quickest option, and honestly probably wouldn't affect much if you had to take a divot out
Originally Posted by Bramage
Denroll thinks 6" is this long : |--------------------------------------|
So take that into consideration
Bahahaha
I've actually considered relocating the throttle body so the 90 isn't such a tight fit. Out of curiosity, can anyone with a 90mm measure vacuum in the supercharger inlet at wot for me? We already have a port with a plug, just need a line and a gauge
Old Sep 4, 2014 | 11:28 AM
  #52
Bramage's Avatar
F-250
Scoto, your **** looks good. What mods did you do to cooling. I see tank and lines.. any mods to Inter-cooler core or inter-cooler fittings?
Looks great!
Old Sep 4, 2014 | 02:21 PM
  #53
Denroll's Avatar
'06 E55
^His intercooler setup was the inspiration behind mine. I think it's the same; single pass core with larger fittings and 3/4" lines.
I did some grinding last night. Taking longer than I had anticipated. Pretty much that entire side with the BBK logo needs to be whittled down.
Old Sep 8, 2014 | 01:01 AM
  #54
Denroll's Avatar
'06 E55
It's alive!
Started her up tonight and she fired on the first attempt.
I did get the TB to fit, but it took a ridiculous amount of grinding on the surge tank and TB housing. I reinforced the surge tank from the inside with some plate steel.
I had to splice the return line from the s/c for the reservoir. The first tee is at the highest point in the system with the other tee a little farther down. This makes bleeding the system super simple. Just turn on the pump (you do have it powered with the key in pos 1, right??) and pinch the hose in between the two T fittings. This forces the coolant through the reservoir and all the little bubbles come right out. I left the pump running for about 30 minutes and hit it with the IR thermometer. 117 degrees. It does sound like it is not working as hard now. When I pinch the 3/4" line and it has to pump through the 5/8" line, the motor noise from the pump increases.
I gave everything a fresh coat of paint and even hit the TB cover with some flat black. I'm going to put a Mercedes emblem right there in the middle of the cover.
Now I just have to finish building my intake. Soon!
Old Sep 8, 2014 | 01:10 AM
  #55
biggking's Avatar
2004 E55 AMG; 1991 Previa
Are you going to do the KC kit?
Old Sep 8, 2014 | 01:29 AM
  #56
Denroll's Avatar
'06 E55
It's been on my mind for a while. The a/c is kinda wimpy, though. I saw Toadster had that hose replaced and his a/c was dramatically better. I might try doing that and see if it helps. If not, I'll just rely on the ol' water/meth injection to keep things under control.
Old Sep 8, 2014 | 06:29 AM
  #57
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
How did you hold the steel reinforcing plate in place? Sounds I little sketchy, although the rest of your work is beautiful. It will look really classy when it's together!
Old Sep 8, 2014 | 09:22 AM
  #58
Denroll's Avatar
'06 E55
I used a big wad of bubble gum. Big League Chew, not that cheap-*** Bazooka stuff, either.
Nah, I used JB Weld. I'm a believer in that stuff.
Old Sep 8, 2014 | 08:20 PM
  #59
I trust the slow kind too, but the JB kwik has let go on me with heat.
Old Sep 8, 2014 | 10:29 PM
  #60
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
Looks great!
Denroll is correct. I modified my inter-cooler to a single pass unit with 3/4 fittings & had it ceramic coated. I have a 2.5 gallon tank with silicone 3/4" hose, I copied Lowprofiles idea & ran 2 pumps in series, I also have a Killer chiller & meth injection. I added a 12v 4 way valve that I can bypass my Eurocharged heat exchanger as my car runs cooler with out it for shorter runs but needed for road racing (20 minute runs)
Old Sep 8, 2014 | 10:41 PM
  #61
Denroll's Avatar
'06 E55
You probably have the best 55k cooling system on the planet.
Old Sep 9, 2014 | 01:11 AM
  #62
Denroll's Avatar
'06 E55
Finished up the intake tonight. I needed some 90 degrizzle elbows and did not want to wait. Found a place that had some in town. Turns out they were not black like the rest of my setup. You know what? I ain't even mad. I kinda like it.
I hit the aluminum tubes up with some ceramic paint to match the supercharger.
I need to reroute my return coolant line, but for now, it's functional. These enclosed filters were bigger than I thought. Had to do a little grinding on the housings. Purple Power!
Old Sep 9, 2014 | 03:09 AM
  #63
thunderclaps's Avatar
E55 AMG, 04STI, 07GTI, 05 HAYABUSA, 05 GSX1000
NICE.
Old Sep 9, 2014 | 03:17 PM
  #64
wes459's Avatar
2006 SL65 AMG, 2014 E350, 2012 ML350 Bluetec
Looks awesome!!!
Old Sep 9, 2014 | 04:07 PM
  #65
berti_00's Avatar
2016 Cls63s AMG
looks killer homeSlice.... love it
