Undervoltage Diagnosis Help
2015 ML63, 2008 Toyota Tacoma, 1995 Porsche 993 C2, 1997 Porsche 993 Turbo
I have read through several useful threads on this topic. Thanks to everyone who posted previously.
Last night I smelled something hot (electrical) when I got out of the car.
Three hours later I drove the car home and the AC was blowing hot air. Ten minutes later a RED message popped up - Undervoltage. Switch off consumers. Visit workshop. This was quickly replaced by Conven. Functions temporarily unavailable.
This morning I noted the following
Thanks in advance for sharing your thoughts.
- Car off - battery voltage is 11.75
- Car running - battery is 11.65
- Front battery was replaced 9 months / 10,000 miles ago
- Rear battery looks to be original
- Serpentine belt seems OK and alternator is spinning
That makes sense. Thanks.
07 E63 + 07 CLK63CAB
9 year old battery, please tell me that it is not true. 11.V anything is a dead cell battery, forcing the alternator to try and charge this huge resistor burning out the reg or even the alternator. 05 new alternator would probably be a good idea and also change out that old battery before starting the car again, next will be the starter as it is taking a beating trying to start with low voltage.
Since you said you smelled something, sounds like the alternator to me.
You can get them redone, it's usually the diodes that burnout. Or you can just get one from a junk yard for like $100.
The alternators themselves are pretty tough, they only really go bad when some outside source causes them to (other than the voltage regulator which can wear out over time)
You are absolutely right. I removed the voltage regulator cover with the alternator still mounted in the car and saw that some of the plastic on the back of the alternator had melted and burned.
So I pulled the alternator and took it to a shop to see if they can salvage it. I pulled the fan shroud and had to remove the S/C coolant lines and the big hose leading to the radiator where they attach to the block to get the alternator out. Not sure how people do it with those attached. I put cardboard over exposed radiator and was glad I did.
Update
I took the alternator to a repair shop today and they reported that the internals were good, but the rectifier had shorted out. This is what caused the burning smell. They suggested replacing the bearings as long as the alternator was out of the car. Total cost for rectifier and bearings (part and labor) was $130. I will install a new voltage regulator (Pelican Parts) for good measure.
