E63 Rotors - blanchard grinding?
Old Aug 24, 2014 | 05:20 PM
VinceB's Avatar
'08 E63 - P 30, 66GT 350 (sold)
I have about 66K on my P030 E63. Bought it CPO at 29K with new brakes/rotors. Been reading various thoughts on changing rotors every time the pads are changed, doing nothing to the rotors (and associated potential issues), etc.
Can't believe how expensive a rotor is... don't want to be cheap but I"m thinking they should be able to be potentially ground. I've always heard grinding is better than single point turning. It looks like they are a 2 piece rotor so all the more reason that they could be ground...
Has anyone had experience with this? What is the minimum width of a rotor? Anyone know a shop in Nor Cal that does blanchard grinding on rotors? Hate to spend $1400+ for 2 rotors through here or even more at a dealer!
Thanks-
Old Aug 24, 2014 | 08:14 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Look into gyrodisc or racing brake. Much better (and cheaper) options than oem. Coming from a dealer tech. Oem rotors are not even directional. I believe someone was trying to start a group buy on gyrodisc rotors. Search evosport rotor hats. I believe it was in that thread.
Old Aug 24, 2014 | 08:28 PM
cij911's Avatar
one car at a time
My humble opinion (based upon most OEMs) is to just change pads and never turn the rotors. IIRC, one can generally get two pad changes for every set of rotors.
Old Aug 25, 2014 | 12:00 PM
ssigarto's Avatar
2007 AMG E63 Weistec S3, 2003 Porsche GT2 with 1375 rwhp
When you decide to replace the rotors, go to RacingBrake.com and buy their two piece. Then, going forward, you only have to replace the rings and reuse the hats. I am very happy with their rotors and am using their racing pads. While it makes a little noise every now and then, they stop on a dime. Also, their rotors come with new pads.
Old Aug 25, 2014 | 01:02 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Thanks-
Hello VinceB,
and thank you all for your comments!
As mentioned we offer light weight two piece rotors for your E63 W211,
Unfortunately OE E63 rotors are higher priced than others and must be replaced as a whole unit when its time to change the rotors. Going with us will allow you to save a fraction of the cost in the long run buy simply purchasing our rings when its time to replace. We send you all the hardware needed along with instructions to bolt on the new rings to your old RB hat. VERY straight forward.
Front E63 RB light weight two piece rotors
Take a look at our weight savings
Weight Comparison (each)
OE One-piece 36 lbs.
OE Two-piece 29 lbs.
RB Two-piece 24 lbs.
RB Weight Savings:
12 lbs. vs. OE One-piece
5 lbs. vs. OE Two-piece
Not only will you shave off some weight, you will have better steering response, acceleration, and braking performance.
Our two piece rotors are truly unique featuring our Open slot, Center-Mount, and Convergent Vane patented designs. All created to improve rotor performance.
Click below to learn more about our two piece rotors
RB Rotor Description
RB Rotor Features
Check out some of our reviews from MB owners.
Racing Brake makes me happy
World's First: RacingBrake 2-Piece Brake Rotors ...
The Ultimate Rotating & Unspring Mass Reduction Thread ...
E63 Front Rotor Replacement DIY - RacingBrake
https://mbworld.org/forums/sl-class-...squealing.html
If you have any questions feel free to ask!
-Chris
