Why Nitrous is NOTHING more than a novelty at best..
You said that same lame comment in your Dyno Clinic ramblings... Besides dumbazz this, dikhead that, shove it, etc you're perpetually mired in a 3rd grade mentality.. You got that 1 gem from your disapproving Principal didn't you..Edit: I could play you mentally like a fiddle all night, but all this nitrous talk has suddenly made me a convert, I need to get up early and hit the Pep Boys an snag me a NOS kit
Boostiality- Both N20 and Meth are both a chemical compound, yes but they do different things. N20,Blowers and Turbos all do the same thing, in a different manner. They all enrich the density of the oxygen per a given swept volume. The blower/turbo does this via pressure, and the N2O does this chemically.
You could compare a meth injection to a N2O kit by saying its similar to half of a N2O kit, lacking the O2 enrichment side of the system. Technically you could use a meth kit as the supplementary fuel for a dry nitrous kit , but at that point you just might as well get rid of the meth and use gas because you have to spray twice the volume of meth as you would gas to make the same amount of power.
Yes blowers/turbos/n2o all generate artificial atmosphere, however in the most fundamental way they operate you have to concede that by using n2o or meth that we're just injecting a chemical(s) into the power equation right?
Ricker: be it running out of juice or meth, you are correct in considering these two as novelty acts but personally I'd rather have the condom and not need it then to need it and not have one.
Molecular formula for nitrous is N2O i.e. Nitrous Oxide. It has two Nitrogen atoms and 1 oxygen atom. Nitrogen is absolutely nonflammable and is also makes up ~79% of the air we breathe.
So since there is more nitrogen in the air than in N2O, why do we use it? In actuality it is completely useless in an engine except for ONE property.....The ability to get cold as f*** when compressed. What actually burns and makes power is the Oxygen and Oxygen alone.
So why not used compressed Oxygen? Well that burns waaaaaaaay too hot and high levels of oxygen in your combustion chamber will result in melted pistons and cylinder blocks.
No chemical injection here, just a controlled way to inject more oxygen into your engine, one that has been compressed already for you before you even mount into your car (N20 tanks). Whereas with turbos and superchargers, you do the oxygen/air compression under the hood.
With meth you are doing just that, injecting a chemical into the engine. Why the difference? Well while methanol is naturally occurring as well, its an insignificant factor where internal combustion engines are concerned. You really use it for the chemical properties of cooling intake charge and allow you to run more timing and leaner mixtures without detonation.
If we're going down this road of discounting injected performance, we should do the same with meth. Their both priced similarly, they both require tuning and life sucks when you run out juice.
I have a question about nitrous "haters".... What difference is it if you put on a blower, turbo, headers, different heads, cam, different ratio rockers, bigger heat exchanger, etc.? You are doing a mod to make more power. Why discriminate?
I wouldn't call myself a "hater", but having another tank to fill isn't worth my time (I also don't have to win every race).
Reminds me, I need to refill my bike's turbo and my car's blower...
See what I mean?
I am guessing you have never put a supercharger or turbocharger on a car that did not come out of the factory with said power adder right? The upkeep and work is very much much higher on those two than N2O
N2O is simple, should only be activated after certain rpm, timing should be retarded to safer limits, and enough fuel when it kicks.
Nitrous is thus safer than other power adders in the sense that you can add your own source of fuel for the kit (wet systems).
Problems with nitrous is the same as with anything that is much easier to reach for the masses....its very cheap introductory price. That allows people who will not take the time to put together a much safer worthwhile setup (a lot of times, idiots) to slap it on their Dodge Neons and Honda Civics and with no supporting mods, end up with blown engines.
If you could buy turbos for less than $1000 complete, there will be just as many blown engines from that as nitrous....in fact there will be more than with N2O
The only ones that think nitrous is cheating are those getting beat by nitrous...in thier turbo/supercharged/modified cars.
They should drag a banner behind them while going down the track that states "BUT, BUT, BUT he is running Nitrous while I am only running a turbo/blower" WAH!
"I am guessing you have never put a supercharger or turbocharger on a car that did not come out of the factory with said power adder right? The upkeep and work is very much much higher on those two than n2o."
Yes very poor example but trying to make a point on up keep and "createing" more work for your self.
Yes one turbo and 3 supercharged. The last supercharged set up was turn key every day with a check of the cog belt here and there. Every spring a new belt would go on for the hell of it and that was it. Again if you do not have the insight than you will have problems. The problems usually take some time and help from others to iron the bugs out as best as possible. The DFI, Wide Band and EGT data logging features on my Big Stuff systems helped 10 fold and was the best things I discoverd in engine building. The more you learn the better off you are in just about everything performance wise.
No matter how you cut it, these types of things are supplemental to the equation of making more power as they both can potentially run out and thus leaving you with less power. Personally I'd rather be carrying then be caught with my pants down
If we are talking about an E55 with nitrous, then we are talking two power adders. I wouldn't compare it to a boost only E55. Obviously the nitrous car would have an extra power adder.
You missed this post at the top of this page..
Live & let liveI switched sides and went with the American made E55 aka CTSV. I don't comment much on these threads because many don't like to read posts about a Cadillac on a MB forum. I get it. My comments below could be for either platform though so here goes.
My first CTSV was a simple tune and pulley car. It was pretty fast at 544 HP best 1/8 mile (1/4 mile tracks are too far away) 7.8 at 100 mph on drag radials. It's limitation for mods was the clutch for the manual transmission which takes me to my second CTSV
My 13 wagon is an automatic. When planning mods there were tons of options just like we face (past tense for me) when modding the E55. Cam's, headers, pullies, superchargers or turbos. Turbo kits are 10k and up. Too much for my budget. After market superchargers don't seem to work well for Cadillac's but I know there are some nice kits for the E55 but I don't know what that costs or reliability or how much labor to sort it out properly. Bottom line for me and maybe some of you is that over 600 hp on street tires becomes counter productive. Yes it's cool spinning in the first 3 gears but it really takes drag radials to tame all that horsepower.
The way I set my car up was with some very minor bolt ons for the street and more specifically, the limitations of street tires for daily driving. I then bought a drag pack set up for racing and installed a Nitrous SYSTEM for racing or driving on my drag radials.
To me this is not cheating. It's a planned out method to reach my horsepower goals and to extract a ton of horsepower for my car and my driving style.
I daily drive my car, often with clients in it. I didn't want an obnoxious exhaust note, surging and shaking camshaft or a temperamental tune. Nitrous fit me perfectly at a great value. It's there when I want or need it, extremely reliable and easy to use. I literally twist a valve and flip the arm button, bottle heater switches and that's it. When I hit WOT and the engine rpm goes to 3k it sprays until the RPM reaches 6,500 and it shuts off to shift into the next gear and we do it again.
The performance is impressive. On street tires I have 575 hp. Typical summer weather times are 7.5 at 97 mph. On Drag radials it's 700 hp and 6.8 at 105mph. The other cool thing about this system is it's adjustability. I could easily adjust the horsepower into the 800 range, catch me a winter track rental at MIR and runs low 10 or possibly run a 9.xx 1/4.
The performance is impressive. On street tires I have 575 hp. Typical summer weather times are 7.5 at 97 mph. On Drag radials it's 700 hp and 6.8 at 105mph. The other cool thing about this system is it's adjustability. I could easily adjust the horsepower into the 800 range, catch me a winter track rental at MIR and runs low 10 or possibly run a 9.xx ]
The stock clutch works great on the street but when you add sticky tires and 100+ horsepower they slip on the track. Plus the auto is faster.
Nitrous is just gay (no offense to the gay guys here- Denroll for one)
I'm only running a 100 shot so it's pretty good on needing to refill. Last time I went to the 1/8 mile track I ran 2 qualifying passes and went 3 rounds. The next time I went to the track and ran 2 more passes. When I went to fill them they only took 1.5 lbs.
I can't imagine how fast you went through bottles with a 450 hp setup.
