what diff. fluid should i use?
Old Sep 5, 2014 | 02:15 AM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
I don't really see much talk on here about changing diff. Fluid. Which weight and brand do you guys recommend?
Old Sep 5, 2014 | 02:45 AM
cm60k's Avatar
I'm using 75W-140 OEM Castrol SAF-XJ LSD fluid #: "001 989 52 03 10"..
ZAYED,,
Old Sep 5, 2014 | 03:43 AM
It's that synthetic or do I still have to use the synthetic additive. How many quarts does it take?
Old Sep 5, 2014 | 04:14 AM
cm60k's Avatar
Not sure about E55 pumpkin, maybe 2 bottles, friends here could confirm that,,
prefer to use 2 bottles of diff. additive #: "000 989 82 03"..
ZAYED,,
Old Sep 5, 2014 | 05:41 AM
StuttgartAMG's Avatar
E55 AMG (W211)
This question is not that easy to answer!
There were 2 different families of diffs mounted in the E55:
2002-2004: HAG210E ("screwed" side shafts to flanges at the diff)
2004-2007: HAG215FE ("plunged" side shafts without flanges)
Both are made for different hypoid fluids (bearings, seals, tolerances)!
An the next question:
Do you have a LSD mounted?
If yes, stock LSD or after market?
Diffs with LSD need a different fluid, because the wear of the LSD clutches and the wear of the fluid is much higher with "stock fluid"!
Stock fluid cracks to fast in diffs with LSD, so it becomes to thin to lubricate all components in the correct way (bearings, seals...)
Old Sep 5, 2014 | 05:49 AM
cm60k's Avatar
+1000000000..
ZAYED,,
Old Sep 5, 2014 | 06:14 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I've got an 06' with stock LSD. It's the only fluid I haven't changed yet. What should I use?
Old Sep 5, 2014 | 06:58 AM
cm60k's Avatar
Assuming YES,,
preferably with additive..
ZAYED,,
Old Sep 5, 2014 | 09:39 AM
I have an 03, how do I know if I have lsd or not?
Old Sep 5, 2014 | 09:59 AM
kompressede's Avatar
Sold - 05' E55
I had good results with this
Old Sep 5, 2014 | 10:07 AM
berti_00's Avatar
2016 Cls63s AMG
I used oem and it's super super easy.
